Boxing 53 f100 frame
Old Apr 1, 2018 | 11:09 AM
Pappys53's Avatar
Pappys53
I am getting ready to tear down my 53 f100. I want to box in the front rails. My delima is I have a Toyota power steering box and I have a cross member for a 350 motor. I was wondering on the left side if the boxing could be up to the cross member then to the steering box then from the steering box on back.?
Old Apr 1, 2018 | 11:16 AM
56panelford's Avatar
56panelford
I don't think it's necessary to box the front frame rails with a stock suspension..
Old Apr 2, 2018 | 08:20 AM
bjmayberry2's Avatar
bjmayberry2
Veteran: National Guard
Pappys53,
Why do you want to box the front frame rails. More flex occurs between the original rear motor mount and rear suspension.
on another note, How’s your cab search going?
Old Apr 2, 2018 | 09:46 AM
Justboy's Avatar
Justboy
The only difference boxing will make is that it will trap moisture and make it near impossible to inspect or treat in future. For certain you can miss out the steering box but you are better off missing out the rest as well if you have a beam axle.
Old Sep 25, 2021 | 05:08 PM
thomc's Avatar
thomc
Unless I am missing something it appears that the smaller boxes are remanufactured earlier (67-72) boxes, but will fit in place of the 76 & up "Volare" boxes. If so, I'm surprised someone on here hasn't discovered the swap before. I've never had a clearance problem, but all (4 or 5) of the Volare IFS swaps I've done have been under '56 frames.
Faber
18
Aug 24, 2015 01:03 PM
Samsn4
Aug 25, 2012 05:57 PM
highboy390fe
Offroad & 4x4
Feb 6, 2006 07:50 AM
mwkobe
Dec 21, 2003 05:36 PM
