e40d overdrive button
Old Mar 31, 2018 | 10:36 PM
94iditpuller's Avatar
94iditpuller
Question e40d overdrive button
when truck is in park overdrive light is on. when i put it in gear light goes off. when going down the road the button works fine trans has all gears. has anyone had this happen. thanks for any info.
Old Apr 1, 2018 | 08:05 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
The wires to the shift handle have worn through the insulation. If you remove the plastic cover from the steering column you can inspect the wires where they enter the shift handle. That's probably where the problem will be found.
Old Apr 2, 2018 | 07:11 AM
94iditpuller
thanks mark . as always you are very helpful . this site could use more like you!!!:-
Dbl A
Apr 8, 2017 02:28 PM
lievense81
Aug 26, 2015 06:38 PM
NBT22555
Jun 25, 2014 01:32 PM
wameyer
Nov 15, 2013 10:32 PM
ken kenmnedy
Oct 23, 2012 08:08 PM
