Another P0305 Problem.
Old Mar 30, 2018 | 03:36 PM
Mrbadlands's Avatar
Mrbadlands
2013 F150 5.0L
I am at a loss. I started getting a P0305 (Cyl #5 misfire) a while back. If I am on a trip and ignore it, I will get a P0300, P0306, and P0308 as well as those same codes with a pd next to them. This truck runs really smooth. Periodically I will pick up a shudder while stopped or on the road in the 45-55 mph range climbing a slight incline and it is not usually associated with a CEL.
Initially I purchased a coil pack. I replaced #5. when problem came back I hop-scotched that coil pack to all the rest of the plugs. Still get the P0305. When that did not work, I replaced the plugs. Still no luck. After reading more I replaced the fuel injectors. Still no luck.
Not sure where to go next. I did see a reference to checking the fuel pressure, but not sure where to connect up and what to connect to do that. I would hate to go through replacing the fuel pump if it is not low pressure or causing the problem.
Any other recommendations?
Old Mar 30, 2018 | 04:06 PM
FordyBest's Avatar
FordyBest
I encounter a similar code on a trip and someone help me fix it... I was on break then but i believe it has to do with the fuel pressure...
CWorthington09
1983 - 2012 Ranger & B-Series
Feb 15, 2018 12:07 PM
Mental-issues
23
Apr 2, 2017 07:14 PM
yerbusiness
Kansas Chapter
Nov 1, 2006 05:17 PM
illuzion
1978 - 1996 Big Bronco
27
Sep 24, 2005 07:32 AM
