Rebuild an F4 in 60 Days
Old 03-30-2018, 09:49 AM
acl9865's Avatar
acl9865
acl9865 is online now
Carryover from my F4 build log which for the past 3 days now I've been unable to add to as it just times out..
So anyways I've made the decision to have the whole truck done by June 1. 63 days from today but I'll be out in Joshua Tree + Easter so lets say 60 days flat.
First picture is where I started when it moved into my garage, second picture is where I'm at today.
Front axle removed and prepping for paint.
New main leaves coming from Eaton Detroit Springs.
Front half of frame POR15'd, second half shortly.
New clutch and conrod bearing coming, as well as transmission gasket set.
High build primer, platinum body filler, and 50 lb of sand paper inbound.
Paint ordered.
Paint booth reserved.
New tires ordered.
Last 2 wheels dropped out for sandblasting and powdercoating.
New glass all around in the mail.
New bench seat kit ordered.
New grille ordered.
New lower grill valance ordered.
Old 03-30-2018, 10:23 AM
tip49's Avatar
tip49
tip49 is offline
Ambitious schedule
Remember to breathe. That will be like one of those TV shows; are Foose and his boys waiting in the wings?
The frame is looking shiny! Love that POR.
Good luck with your project, and make lots of coffee.
Old 03-30-2018, 10:33 AM
acl9865's Avatar
acl9865
Luckily I have the Amazon Red Bull button for quick ordering haha. I wish Foose was nearby, just my puppies and I and the occasional garage visit from my girlfriend.
I'm cheating slightly and taking 4 weeks off of work too.
Old 03-30-2018, 01:28 PM
Jolly Roger Joe's Avatar
Jolly Roger Joe
Jolly Roger Joe is offline
I want to watch this. I didn't do nearly what you have planned to my F4, and it took me 5 1/2 years.
Good luck.
Old 03-30-2018, 03:33 PM
Aloha-boy's Avatar
Aloha-boy
Aloha-boy is offline
I'm definitely pulling for you! Wish I could lend a hand. Good luck!
Old 03-31-2018, 01:56 PM
acl9865's Avatar
acl9865
Good luck.
Thanks, 62 days to go and I'm still buying parts.
Stop on by! Beers for everyone.
Old 03-31-2018, 08:58 PM
Marauder2004's Avatar
Marauder2004
Marauder2004 is offline
Hat's off to you!
Old 04-05-2018, 09:17 AM
acl9865's Avatar
acl9865
Update: 57 Days Remaining
All I've managed to do is prime the fenders. Have some major work deadlines to hit and free time has been at an all time low.
On the upside my last bearing, motor mounts, more POR 15, new 10" clutch, transmission gasket set, and new throwout bearing are here now too. Goal for this weekend is to finish the motor and transmission and drop them in.
Pending the workload of course..
Alex
Old 04-05-2018, 01:18 PM
FortyNiner's Avatar
FortyNiner
FortyNiner is offline
As you are racing toward your goal, you may want to ensure you've got all the replacement rubber items that will be needed. Since you are painting, I'll assume that you'll need weatherstripping for the doors, bumpers/seals for the pedals, a shifter boot, .....and so it goes. Often, these items just need to be on hand for the reassembly to not get delayed. Going back to install after the right time window wouldn't seem to be in your project schedule.
Dennis Carpenter is a solid source with Steele Rubber the gold standard. IMHO
What are you doing for wiring?
Old 04-05-2018, 01:27 PM
acl9865's Avatar
acl9865
Thanks for pointing that out. Ya I have a spreadsheet I made on day one, a comprehensive BOM to completion. I have suppliers locked down for all my rubber items and I'll probably order them the week before I go into paint.
I think DC was actually my chosen supplier for rubber but I'll double check. Thanks for the recommendation.
Doing all my own wiring from scratch.
Old 04-05-2018, 01:40 PM
abe's Avatar
abe
abe is offline
One Meadow Green Owner
Received 2,616 Likes on 1,456 Posts
Buying a ready made harness would save you time.
Old 04-05-2018, 01:42 PM
acl9865's Avatar
acl9865
Ya I'm sure, but wiring is one of my favorite parts. Maybe it's the engineer in me. I've already ordered all my wiring, loom, and breaker boxes. Already printed all the grommets and conduits I'll need as well.
Old 04-05-2018, 01:43 PM
abe's Avatar
abe
abe is offline
Good for you! Wiring is some guys least favorite thing to do. You'll save money this way.
Old 04-07-2018, 07:50 PM
acl9865's Avatar
acl9865
How much of a tight spot am I in?
Also, how much rotational play should the gear stick have? I can rotate the level between 6 and 7 oclock freely before it reaches the end of its travel. Is that normal?
Old 04-07-2018, 08:00 PM
Jolly Roger Joe
Well, that's not good. IIRC that is cast iron. I know cast iron can be MIG welded, but the bearing retainer is critical for the correct alignment of the trans to the drive shaft. Is it just the angle of the pic, or is that bearing shot?
Quick Reply: Rebuild an F4 in 60 Days
