snow prep package leveling question
Old Jan 31, 2019 | 08:02 AM
CaptainDeadpool's Avatar
CaptainDeadpool
Originally Posted by evil1art
i had to cut the small plastic pieces of the bottom of tbe fender but im running 20x10 with -12 offset
looks great, I suspect my truck will sit about the same come this spring except a little less poke. What kit did you add to the rear and was there anything you had to add to the bds kit it didn’t come with? Castor bushings etc
Old Jan 31, 2019 | 08:04 AM
Joe T's Avatar
Joe T
How much does the heavy service front end lift the front over stock? 2019 6.7 diesel.
Old Jan 31, 2019 | 08:11 AM
evil1art's Avatar
evil1art
kit comes with caster camber bushings and i added a 4in block to the rear
i am adding bds radius arms i dont like the angle of the balljoints with the caster moved that much
Old Mar 9, 2020 | 12:51 PM
Mkimbel's Avatar
Mkimbel
I posted this on a different thread, I know its a little late but thought it may help someone else...I have a 6.2L 2019 4Door short bed with snow plow prep. I added the readylift 2.5 with trackbar relocation bracket. It ended up giving about .5"-.25" nose high depending on tire pressure. This gave me caster issues big time, ride was terribly harsh. Added caster shims (2.5°) and radius arm drop brackets (had to grind the brackets to fit the frame as I bought ones for a 16) after doing that I added a dual steering stabilizer from rough country. The difference is ten times better now, no more flighty and loose steering/bump steer/death wobble, and smoother ride. If you don't make these caster adjustments you will be disappointed. I also used forscan to drop my TPMS thresholds and I now run my tire pressure at 50 front 45 rear on stock 275/70/18 tires and the ride is night and day! I've pulled my trailer with 3 yards of top soil on it, and didn't air up the tires and it didn't really make a difference for reference.
Measurements are 44.25 front and about 43.75 rear or a touch over from ground to fender well.
Old Mar 9, 2020 | 07:00 PM
jlamb02910's Avatar
jlamb02910
anyone have a f250 with snow prep package and a level kit? plow package springs are 1in taller then standard.
spoke to BDS about 2in kit and they had no idea what i was talking about said that the shocks should be ok and it should work.my question is being i already have 1in and im adding 2 more will the track bar and shocks fit being they are rated to a standard truck spring?
also spoke to ready lift and got the same response
any help will be appreciated i would rather not change spring but it looks like i might have to
I Have the snow plow package and put a 2" BDS leveling kit along with caster shims, longer Fox shocks and adjustable track bar.
Old Mar 9, 2020 | 07:08 PM
sheranian's Avatar
sheranian
Do you have any pictures of the Truck with the 2” BDS? I’ve thought about this kit a bunch... how do you like it the ride before and after. Trying to decide between this and Carli springs and parts.
Old Mar 10, 2020 | 07:12 AM
jlamb02910's Avatar
jlamb02910
Here is a video of the install
https://www.facebook.com/MountZionOffroad/videos/794787567608303/
Old Mar 10, 2020 | 07:17 AM
jlamb02910's Avatar
jlamb02910
Old Mar 10, 2020 | 07:20 AM
jlamb02910's Avatar
jlamb02910
I'm having a problem uploading the video. Go to Facebook Mt. Zion Offroad Videos. look for the F-250 leveling kit video. That's my truck
BADAS03SVT
Jul 16, 2018 04:51 PM
bigjeezy86
Apr 3, 2018 10:22 PM
LadderDogV10
Feb 9, 2018 10:59 PM
FORD-DNA
6.7L Power Stroke Diesel
Mar 29, 2012 10:16 PM
rhodeisland350
Apr 14, 2008 08:18 PM
