2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
2007 El Limited passenger seat stuck in recline.
Old 03-30-2018, 06:15 AM
mpgo4th's Avatar
mpgo4th
mpgo4th is offline
I was working on the blower motor and must have been hitting the seat switch with my body. When I got up it was in full recline. I checked power to the motor at the switch and it was good.I ended up taking the whole seat apart because we are leaving on a trip today and I had to get it back up. I was able to use a jump box to put power and ground to the recline motor and get it to come back up on it's own.reversing the two leads made the motor move back to recline. So at this point I know the motor works. I used a meter to check voltage at the motor with the switch pressed. In recline it had 12.1 volts but going back up the switch only gave it 8.9-9.5 volts. I checked resistance across the switch for this function and got 405 ohms. Is this correct resistance? My gut tells me its a bad switch but I'd like to make sure before getting a $120 part to try.
Old 03-30-2018, 06:21 PM
gpineau's Avatar
gpineau
gpineau is offline
i am voting on a bad switch.
Old 03-31-2018, 01:51 PM
alloro's Avatar
alloro
alloro is offline
Received 4,196 Likes on 2,432 Posts
It should be zero...bad switch. You might've damaged it when leaning on it.
Old 07-07-2022, 03:41 PM
1SRVFAN's Avatar
1SRVFAN
1SRVFAN is offline
1st Gear
Same problem here
Same problem...the seat got stuck in recline position. However, I replaced the entire seat track from a Navigator from the salvage yard and the recline still didn't work....all other buttons did. I also removed the drivers side switch and connected to the passenger side and still everything worked except recline. Any thoughts?
dakotajeep
02-13-2014 02:22 PM
stewartjwnls
09-05-2011 05:55 PM
IHMANKY
12-28-2010 01:00 PM
ataboc
11-30-2010 04:53 PM
Quick Reply: 2007 El Limited passenger seat stuck in recline.
