Bolt size
Old Mar 28, 2018 | 05:39 PM
DDT11's Avatar
DDT11
Bolt size
I just got my new 5th wheel and when I went to plug in the electrical cable, I saw that the bolts that hold the plug in are missing. I went to the dealer and they cannot find the correct specs on the needed bolts. Does anyone have the particulars on the needed bolts? I have attached a photo to show the ones I need.
Before you ask, no, I wasn't very impressed with my parts person. The Ford catalog did not have the correct diagram, but he could have gotten his fat *** off the stool and found something.
Old Mar 28, 2018 | 08:14 PM
Xwild's Avatar
Xwild
Don't know off the top of my head, but are the nutclips in place? If so, you can pop one off and take it with you to the hardware store to figure out the thread. And if they're not, you're also missing the nutclips.
Old Mar 29, 2018 | 08:00 AM
wrvond's Avatar
wrvond
Mine is aftermarket, but I imagine Bargeman (or Pollack) are pretty standard. I'd go with M8.
I'd also recommend pulling the plug out of the hole to ensure you have something to screw them into. There should also be some kind of insulator to isolate the bolts from the aluminum.
Old Mar 29, 2018 | 08:10 AM
troverman's Avatar
troverman
Unless you had an aftermarket bedliner installed and that company removed the bolts, Ford needs to be responsible for this. You paid a lot of money for a vehicle and shouldn't have to be performing any "work" on it in order to make it right.
But, as you likely know, its probably a lot easier to just go to a hardware store and find the bolts you need.
Old Mar 29, 2018 | 08:39 AM
69cj's Avatar
69cj
I agree 100%. Give it to the dealer and tell them to fix it.
fabieber
Nov 14, 2015 10:18 PM
Rojak
13
Aug 20, 2013 08:02 PM
GruesomeJeans
1978 - 1996 Big Bronco
May 4, 2012 12:05 AM
TheWiz427
15
Sep 23, 2007 11:27 AM
buckeyebronco
Aug 30, 2003 01:44 AM
