PTO Gear backlash
Old Mar 27, 2018 | 05:22 PM
shaffecv's Avatar
shaffecv
PTO Gear backlash
Hello All,
The ZF-5 in my 92 F-Superduty service truck has gone south.
Will be installing a remanufactured trans this week.
Does anybody know the backlash spec for the PTO unit main gear to the drive gear on the secondary shaft of the transmission.
I remember the procedure from back in the day, but not the amount.
Old Mar 27, 2018 | 08:41 PM
moose4x4's Avatar
moose4x4
FTE Emeritus
Chelsea says .006 - .012 inch. for 6 or 8 bolt PTO's
Old Mar 27, 2018 | 09:17 PM
shaffecv's Avatar
shaffecv
Thank You Sir
Old Mar 27, 2018 | 09:40 PM
ford390gashog's Avatar
ford390gashog
FYI for what it's worth on the ZF go for the higher side of the clearance. The case expands a lot and a cast iron PTO acts like a heat sink. We swapped hundreds of these in the late 90's on service trucks. They always were set to a tight spec and when the trans heated up the gear mesh was dramatically reduced and the area around the pto didn't expand at the same rate and caused cracks to form and gears to bind up, some even pushed the PTO right off the case. I always set to .10 when the transmission is cool at ambient temp. I believe there is a guideline for this in the ZF rebuilders and applications book. I will try to find my old book and see.
Old Mar 27, 2018 | 09:44 PM
moose4x4's Avatar
moose4x4
FTE Emeritus
Originally Posted by shaffecv
Thank You Sir
Your welcome!
Old Mar 28, 2018 | 07:06 PM
shaffecv's Avatar
shaffecv
Got it set up at .10 on the bench. On the jack and ready to bolt up in the morning.
Thanks for the help.
95seventhree
Dec 28, 2015 10:34 PM
ALBUQ F-1
Jan 12, 2015 10:28 PM
lasthighboy
Jul 22, 2012 03:21 PM
99F150
3.8 & 4.2L V6
Aug 31, 2004 08:59 PM
Tom92F150
1966 - 1977 Early Broncos
Apr 6, 2003 11:33 PM
