Fuel tank issues
Old Mar 28, 2018 | 03:03 PM
Jonathan Lentzkow's Avatar
Jonathan Lentzkow
5th Gear
Fuel tank issues
I have a 1989 F150 XLT Lariat, I'm having trouble with the rear fuel tank over flowing/ building up pressure when I run the front tank so ivI' been running on rear tank, problem with that is the gauge doesn't work for the rear but it does for the front and it won't let me put gas in the rear tank but I can fill the front tank. Sorry for the large font don't know how it's so big.
Old Mar 28, 2018 | 05:01 PM
rla2005's Avatar
rla2005
You have a bad Dual Function Reservoir. It's mounted on the driver side frame rail. Both tanks feed into it, the other side goes to the engine. Your symptoms are classic failed/stuck DFR. It can be removed and disassembled. Some folks have managed to repair them, but it is rare.
For reference a photo:
courtesy of Steve83
More information on how they work: 1984 to '89 Fuel Reservoirs
Old Mar 28, 2018 | 05:43 PM
rla2005's Avatar
rla2005
Welcome to FTE!
Old Mar 28, 2018 | 06:39 PM
94ZR580's Avatar
94ZR580
The problem you appear to be having is with the valves inside the DFR not responding properly and the fuel return from the engine is all going to the rear tank when you are running off the front tank. If the rear tank is working fine then you maybe able to monitor your usage by using the trip meter to gauge how much fuel you have. I use the trip meter in mine as my gauge is not accurate, except for right near empty. New DFR's can be difficult to come by and are usually fairly expensive. I've disassembled and cleaned mine once, but it appears to be sticking again. One solution is to eliminate one tank and the DFR. Do a search and you'll find a number of threads on this site dealing with this issue.
Old Mar 28, 2018 | 07:07 PM
Jonathan Lentzkow
5th Gear
Thank you
Your replies are very insightful
stopp429
Feb 15, 2013 06:42 PM
lud04X
Dec 3, 2011 09:58 PM
tralfamadorian
Mar 15, 2009 02:49 PM
scozim
Jun 11, 2006 12:14 AM
sillyfilly
May 9, 2002 01:15 AM
