Hello,
My 2010 Super Duty just started to show bubbles by the rear wheel well which means rust is coming through. A local restoration/body shop who does many classic cars and trucks, says he uses LMC panels and will cut out a big portion of the wheel well and replace with an LMC panel. He uses LMC quite often and says there are good.
I've been doing a bit of research and I'm hearing a lot of bad things about LMC panels, like poor quality, not fitting properly, and of course Chinese junk. Has anyone had any recent experience with LMC panels?
That would do it,hard to think it would rust in 8 yrs,
Believe me, I'm not too happy about this but have read where others have had the same issues or with bed supports totally rusting out at a very young age.
Craig, from my experience with LMC, I'd stay away from them, unless you absolutely have to. I've had nothing but bad luck with their stuff. But, I wasn't buying for a 2010 , and maybe that stuff is better. I'd still check around, though.
Dennis Carpenter sells replacement panels, but they are just a distributor, like LMC. There's no telling where the panel you get will come from. I ordered floor pans for my 69 and the driver side came from California, the passenger side from a different company. Neither fit without a little persuasion.
If you're doing the work yourself, get what you want. I would think Ford sells replacement panels for a truck that's only eight years old. If the body shop is doing the work for you, just make sure they guarantee the work or find someone else who does. Either way, that panel will need to be fit into place, even if it was cut from a clean truck in a junkyard.
I just got an LMcC tailgate for my 68 and it’s the real deal. Weighs a ton just as ordered. I considered getting some Lmc patches for the bottom of the wheel wells but found a
local shop who would cut in new metal and prime
it cheap. They are probably good though
That is an excellent point. However, body panels DO warp from fatigue, heat/cold and regular wear & tear, especially on a vehicle that is 50 years old. Plus, the stamping/forming means may have worn when the replacement part was made too. There's always some tolerance on both sides, requiring some adjustment and tweaking to make a good fit. To borrow a phrase from other forums : The result is only as good as the donor. If my RX-7 needed a new quarter panel and I bought it from Mazda, it probably wouldn't be a perfect fit either. But a patient, talented body shop that takes pride in their work can work wonders to make it fit correctly. Wish I had that kind of patience.
OP -- old thread, not sure you're around, but a 2010 Ford Product rusting out ? (Are you near the beach or something?)
Regarding LMC --- AVOID their garbage.
I've been using Sherman (Michigan) for years --- decent quality stuff..................
My truck has never been on the beach or by salt water. Of course Delaware does use brine and road salt during the winter. The body shop doing my repair says he has seen lots of Ford's rust in the wheel well area.
As far as LMC, I really have no choice since this restoration shop uses lots of their panels and does not have customer complaints.
I recently purchased a front bed patch panel from LMC and it came from TABCO. LMC was the only source for this panel that I could find. So far, I haven't had any problems with any of the parts I have used from LMC.
I used TABCO for my 81 F100 floors, rockers, lower rear part of the door posts, cab corners and the inner & outer lower part of the left door.
I did all the work myself and was vary happy with the fit with all of them.
When I first placed my order they called me to tell me some of the panels over lapped by a lot and what ones they felt I would not need.
They said they would send a sheet of flat panel I could use to patch any area not covered. I said ok and that's what the did, saved me some money.
Dave ----
