Sponsored by: Real Truck
Trans Line Info Needed
Old Mar 26, 2018 | 04:35 PM
Mitragorz's Avatar
Mitragorz
1999 F250 Super Duty, 5.4L 4WD.
What size is the transmission line going into the passenger side of the case? 5/16?
What's the thread size on the fitting on that side? The previous owner somehow broke it off an decided that JB Weld was the best fix...
Thanks.
Old Mar 26, 2018 | 06:18 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
It's a 3/8" line. I don't know the thread.
Old Mar 26, 2018 | 10:54 PM
Mitragorz's Avatar
Mitragorz
Ok good, that's half the battle.
Thanks.
Old Mar 27, 2018 | 01:35 AM
StrokinHer01's Avatar
StrokinHer01
Half inch National pipe thread?
Old Mar 28, 2018 | 02:48 PM
Mitragorz's Avatar
Mitragorz
If I drop the pan, do I have access to the other side of the hole so I can block it off? I’d need to prevent shavings from contaminating the tranny.
Old Mar 29, 2018 | 08:22 AM
Mark Kovalsky
No, you do not.
Old Mar 29, 2018 | 08:34 AM
Mitragorz's Avatar
Mitragorz
What’s the best way to keep shavings out of the tranny? Wadded up ball of tape, then fish it out with a pair of needle nose?
Old Mar 29, 2018 | 12:30 PM
ligito's Avatar
ligito
Vacuum ?
Old Apr 1, 2018 | 10:23 PM
Deagle12's Avatar
Deagle12
What about putting an inline filter on the trans oil line?
Old Apr 2, 2018 | 04:31 AM
Mitragorz's Avatar
Mitragorz
So the passenger side is the output to the oil cooler? That’s a good idea, then. I can plumb in a filter, drive the truck for a while, then either replace the filter or just repair the line.
Old Apr 2, 2018 | 10:44 AM
Mark Kovalsky
Both the output to the cooler and the return from the cooler are on the passenger's side of the transmission. The front fitting is the output, the rear one is the return.
Old Apr 2, 2018 | 10:48 AM
Mitragorz's Avatar
Mitragorz
I’m pretty sure that’s the return, then. I’ll have to crawl back under the truck to double check, but the busted fitting is at the rear passenger corner of the trans pan.
Filter wouldnt be any any help in that case.
Old Apr 2, 2018 | 01:11 PM
Mark Kovalsky
That is the return fitting.
thendrix
Mar 24, 2017 02:22 PM
ToddGatman
Jun 4, 2010 02:21 PM
Bin Strokin
Jun 15, 2008 06:51 AM
1955effie
Jan 9, 2007 05:15 PM
