Rear brake failure
Old Mar 25, 2018 | 12:21 PM
afonda's Avatar
afonda
Rear brake failure
Caliper froze up on reaar passenger side... outer pad was almost like new.. inner pad and rotor destroyed... had to get all new components.
so.. I initially thought I was having an issue on the front drivers side. I inspected, bled whaat looked to be one big air bubble out of the system .. reassembled.. went to go for a test drive and the brakes locked up but only in reverse. Perplexed I said "WTF"... turns out not the front at all..
now with all fixed up, the truck pulls to the right when stopping.. WTF ?
Old Mar 25, 2018 | 02:16 PM
Colorado350's Avatar
Colorado350
Did you rebuild BOTH sides or just the passenger (right) side?
Old Mar 25, 2018 | 02:35 PM
Walleye Hunter's Avatar
Walleye Hunter
If you could drive it around and work the brakes a bit then check your brake temps with an IR thermometer it should identify where the problem lies, then you could start to trouble shoot it.
Old Mar 25, 2018 | 07:48 PM
afonda's Avatar
afonda
Both sides of course...
Old Mar 25, 2018 | 08:15 PM
Colorado350
New hoses?
Old Mar 25, 2018 | 10:18 PM
afonda's Avatar
afonda
New hoses?
no. New caliper, rotor , pads.
Old Mar 25, 2018 | 11:08 PM
Colorado350
You could have a collapsed hose that prevents the new caliper from releasing. I always do hoses when I replace calipers for that reason.
Old Mar 26, 2018 | 06:35 AM
afonda's Avatar
afonda
I will keep an eye on it. Thanks for the pointer. There appeared to be good flow to the caliper.
Old Mar 26, 2018 | 07:42 AM
Colorado350
The interior of the hose collapses and doesn't allow fluid to leave calipers, then the caliper hangs up and causes the vehicle to pull to one side. You can't see a bad hose if the interior collapsed...
Old Mar 26, 2018 | 08:41 AM
bigb56's Avatar
bigb56
Just a heads up I live in a fairly large city and there were no Motorcraft brake hoses in town for my truck, only some Chinese ones and even those were 100 miles away for both. I ordered Motorcraft from Autonation and waited a week.
imq707s
Apr 13, 2019 06:25 PM
bthr22
Mar 25, 2013 05:44 PM
mrcrownline
Feb 15, 2013 08:07 PM
3TreeGuy
Sep 7, 2009 09:49 AM
Tungsten
Nov 30, 2008 08:01 PM
