Frame Flexing issue
Old Mar 24, 2018 | 08:37 PM
ragboat's Avatar
ragboat
Frame Flexing issue
87 F250, 4X4, 6.9 Diesel. During my efforts to eliminate some of the slop from my steering I have discovered that the frame rail that the steering box is bolted to flexes when the steering wheel is turned. This is partly due to a loose rivet at the engine cradle cross-member. I intend to replace the rivet with a bolt. This will partly solve the problem but will not remove all the flex. I don't believe that anything is cracked yet. I was considering welding in a reinforcement but am wondering if the rails are heat treated. Does anyone know if there are reinforcement kits readily available?
Dave
Old Mar 26, 2018 | 12:01 AM
bbf385's Avatar
bbf385
There are no frame boxing kits or reinforcement kits available for your truck. If you make cardboard templetes you may be able to have something cut locally for a reasonable price.
Old Mar 26, 2018 | 12:46 AM
mrollings53's Avatar
mrollings53
Clean the area up, then inspect for cracks. Beyond that, and loose hardware these frames were built to flex some.
Old Mar 26, 2018 | 04:27 AM
ragboat's Avatar
ragboat
Are the rails heat treated? I have seen some big trucks that have heat treated frames. Welding something to a heat treated will compromise it's strength.
Dave
Old Mar 26, 2018 | 06:35 PM
ifrythings's Avatar
ifrythings
Dave
The frame is not heat treated like big rigs or newer trucks are.
You could put put a front receiver/ hitch on and that would box in the front frame rails, that’s what I’m going to do on my 95, though I don’t notice any frame flex at all.
Old Mar 26, 2018 | 07:28 PM
95fiveoh's Avatar
95fiveoh
The rails aren't heat treated or anything. You can weld on them. I'd try not to get it too hot, but still make sure you get good penetration on the welds. These frames are definitely meant to flex some, though.
Good luck!
Old Mar 27, 2018 | 12:08 PM
willowbilly3's Avatar
willowbilly3
I've rebuilt those frame sections, had a stolen truck come back with the box all but ripped out. Heat treated or not, you have to fix it and if it's moving, one bolt to replace a rivet does not sound like a proper fix.
Old Mar 27, 2018 | 08:53 PM
ragboat's Avatar
ragboat
I'm not even sure I can get a bolt into where the loose rivet is. Anyway that was just to replace the loose rivet. I will make up a reinforcement and weld it on.
Dave
Old Mar 29, 2018 | 11:25 PM
1TonBasecamp's Avatar
1TonBasecamp
It's all pretty awkward in there if I remember. A very common issue with those trucks, but way more so with the diesel. Guessing it's the torque and weight playing their part, or maybe the trucks just get used more. But we used to weld up a lot of them.
When I worked at Trailmaster one customer had a complaint about loosey goosey feeling and a loud clicking right after he put on a 4" lift kit. And this was just in a Bronco. Nothing too radical, but a big crack in the frame, worn out axle pivot bushings and all the extra flex imparted to the frame from the longer pivot brackets was just too much for it.
His truck was already messed up as far as we could tell, but we welded up a good bit of the crossmember to get it go settle down.
Pretty sure the diesel frame and crossmember are at least slightly different, but the overall design and concept are the same.
If you can't get a bolt in there, see if you can get a local welder to tack-weld some key areas to tighten it up. Hopefully yours lends itself to some welding. Been so long since I've fiddled around with that I can't say for sure what, where, when, why and who as far as welding.
Good luck.
Paul
Old Mar 30, 2018 | 08:25 AM
ragboat's Avatar
ragboat
Thanks Paul. Welding a reinforcement seems like the only way to go. It is interesting that you mention the axle pivot bushings. Mine are both pretty well worn. I replaced both brackets several years ago because they were badly cracked. I'm not sure how I will get something under the truck to press the bushings out. They appear to be pretty solid and I don't know if my usual trick with a piece of large all-thread and a big socket will work. I will need to try something though.
Dave
Old Mar 30, 2018 | 01:01 PM
1TonBasecamp
Yeah Dave, we used to have to replace the TTB pivot joints in a lot more customer's trucks than they would have liked. Not us, but the customers! Even the factory ones where the truck had no suspension modifications would wear out pretty quickly under all that stress. Some lasted 50, 70, even 90 thousand miles. Others were toast by 30k unfortunately. 'Cause unless you were doing it yourself, it wasn't a cheap service.
In fact, I think they were the main reason that prompted us as a relatively small company (large by 4wd shop standards though) to become an Energy Suspension distributor.
Unfortunately, all the times we did it I can't say I actually went out to the shop to watch how the mechanics handled it. Maybe they used a ball-joint press right up on the vehicle? I know it wasn't too terrible to drop the axle pivots down below the frame, but it's not exactly without it's perils when you don't have a hoist. Lots of English on those joints just sitting there.
Guess I'll have to check with one of the old mechanics. He's working at a Chrysler dealership now and I think we're facebook friends. Good excuse to say howdy after a long stretch.
Good luck with your flex.
Paul
Brkdncr
17
Mar 20, 2017 11:32 PM
89f150mike
Jul 11, 2006 09:01 PM
f150lariat
Apr 7, 2005 08:26 PM
cummins power
Nov 27, 2003 11:47 AM
nickmobile67
Oct 28, 2003 06:32 AM
