No start ongoing problem
Old Mar 25, 2018 | 03:08 PM
General01's Avatar
General01
Hello again,
lots of great points brought up
I do havw the battery charger on it during all the cranking.
Rpm when cranking is about 140ish
Ipr percentage goes to 85 after a couple of seconds of cranking
But the psi showed on the scanner only bounces between 300 to 500, its never steady
icp is steady at about .4 to .5 volts
have done huge amounts of cranking, and i have done injectors on my other truck before so i know how long it takes, but still the whole system has been opened up as stated above. What do you guys think?
Old Mar 26, 2018 | 08:23 AM
Talyn's Avatar
Talyn
Originally Posted by General01
Hello again,
Here is a stupid one, but check the nut on the end of the IPR and make sure its tight.
You're getting duty cycles, so that means its trying to start, but 85% means its probably struggling for oil.
It's possible you didn't get the nut on the end of the HPOP tight and its slipping. It's a self tightening system, but if you dont snug it right to start, it wont tighten itself.
That's the only other thought I have.
Old Mar 26, 2018 | 01:42 PM
Hussler's Avatar
Hussler
Hello again,
Is the truck chipped? I've never heard of that high of a number (IPR%) unless the truck was chipped with a aftermarket tune. Stock PCM usually will max out at 45 IPR %. 140 RPM is a bit low for a cold start but it should work as long as it's not a chug chug chug and spinning steady. If not already tried plug in the block heater for about 3 hours so the oil heats up a bit, that should enable the engine to spin faster. Make sure batteries are good and starter is not an antique.
Here is some reference information you might want to read: https://oregonfuelinjection.com/serv...gnostics/#1994
hjmurphy98
Jun 6, 2017 08:02 PM
TheTinian
Dec 16, 2013 08:15 PM
cipcom
1997 - 2003 F150
Oct 1, 2013 07:34 PM
russkinnard
15
Apr 23, 2010 07:35 PM
devildog_0431
May 24, 2006 06:39 PM
