another engine/tran swap question
Old Mar 23, 2018 | 10:19 AM
meck1's Avatar
meck1
I'm still trying to figure out ahead of time what problems I'm going to have swapping a '97 engine/tran into my '94 Ranger. I'm not doing this for speed or such, just to replace a very tired engine. I'm wondering what problems I'll run into putting an OBD-II engine/tran into an OBD-I Ranger. If anyone knows of a thread about this or can give me some advice, I'll appreciate it.
Old Mar 23, 2018 | 06:15 PM
Conanski's Avatar
Conanski
Are you swapping in the same engine of something totally different? If it's the same engine then you should be able to make it work with your '94 EFI system and wiring, you may have to change some parts but otherwise it'll work. If it's a totally different motor then you are in for a more complicated project.
Old Mar 23, 2018 | 08:02 PM
meck1's Avatar
meck1
I'm putting a 3.0 and auto tran (4r44e) into a 2.3, manual tran.
Old Mar 24, 2018 | 10:48 AM
spooktn's Avatar
spooktn
never done that kind of change,,,but i think you will need the computer and a lot of the wiring under the hood to pull that off,,,,not to mention motor and trans mounts....trying to remember if a 94 is OBD 1 and 97 is OBD 2 if so you would need the OBD 2 port thats under dash so you could check for codes,,,,bot to mention how to wire clutch safety switch into a auto trans
Old Mar 24, 2018 | 11:11 AM
mfp4073's Avatar
mfp4073
agreed, im feeling both full underhood and underbody wiring harnesses. How would you make the rear speed sensor work? Would you need to swap rear ends for that so the computer has the VSS to know how to shift and such. maybe all the under the dash wiring too so the computer can work with the speedo and such in combination with the VSS.
jlam106
Oct 11, 2016 10:04 AM
turnkyle
Feb 5, 2015 09:25 AM
Robert Thornburg
Nov 8, 2012 10:32 AM
stealth29032
Mar 30, 2007 08:31 PM
ers3383
Engine Swaps
Aug 11, 2004 05:37 PM
