Sponsored by: Real Truck
2016 Leveling Kit Shock querstions
Old Mar 23, 2018 | 09:23 AM
Three30Eighr's Avatar
Three30Eighr
Will a 2016 F250 XLT with a 2 inch leveling kit require new front shocks that are longer? If so, what would a good option be?
Old Mar 28, 2018 | 06:11 AM
Three30Eighr
Hello??? Seriously guys...someone has to know
Old Mar 28, 2018 | 06:38 AM
MadWolf's Avatar
MadWolf
Mine is 2wd, but when i was looking at the hockey puck level kits, they were offered in packages with new extended shocks on some websites. I don't know about the stock 4x4 setup. I'm trying to remember, but I feel like I've seen threads and videos of people just putting the 2" pucks in, and alignment, without doing anything else? Sometimes I think other small upgraded parts may be needed, to hit the right angles with everything.
Old Mar 28, 2018 | 08:07 AM
speakerfritz's Avatar
speakerfritz
it depends how the shocks sit now....if they sit with 1/3 tube exposure at rest, a level kit will probally move the tube exposure to 2/3
if they sit at 2/3rds now, a level kit will like cause the shock to bottom out on expansion
but basically yes, there are different size shocks avail depending on 0, 2, 4, etc inches of lift.
Old Mar 28, 2018 | 11:13 AM
Braggs's Avatar
Braggs
There are leveling kits that go on the knuckle that don't affect the length of travel of the shocks. Easy and cheap.
Here's an example:
https://www.roughcountry.com/ford-le...-kit-514c.html
Old Mar 28, 2018 | 06:16 PM
Hotrod70d's Avatar
Hotrod70d
If you don't want yo purchase new shocks , companies offer shock extensions to get your 2 inches back
Old Apr 3, 2018 | 08:08 PM
DieselBeast01's Avatar
DieselBeast01
I have been digging hard into this, as I am about to level mine. Like mentioned above, it all depends on your current shocks. From what I have seen, 2" or less you can get away with using the stock length shocks, but will want to updgrade the shocks at some point in the near future. Anything over 2" and you need new shocks. I will be going with the rough country kit that is shown above since their pucks are actually molded to the same shape as the coil mount.
Obviously there are better kits/options for leveling your truck, but not everyone has a couple of grand laying around for a Carli kit.
Old Apr 28, 2018 | 10:44 PM
orionife's Avatar
orionife
I am putting on Bushwacker fender flares (still looking for proper offset) , with 35x12.5x20. I will also put on a Firestone set of airbags. I have been researching Leveling kits. From the Rough County 2" kit (Mentioned above) for 59.99 with lots of great reviews to the Carli 2.5 for 2300 (do not need that). My questions are as follows; Why would one style of truck have 3 different sizes 1.5, 2.0, 2.5" wouldn't only one size actually level your truck? Do you really not need shocks for the rough country 2" leveling kit?
Thanks
Old Apr 28, 2018 | 10:56 PM
speakerfritz
Thanks
if you put 2.5 level kit , soon as you load up the truck, your lights will be in the trees.
a 1.5 kit allows bed weight with less lights in the trees
the shock question...it depends where you current shocks park at rest. If you have 1/3 tube exposed...a level kit will get you to 1/2 tube exposed which is perfect.
but...if you are 1/2 to 3/4 tube exposed...level kit could result in bottoming out during expansion.
Old Apr 29, 2018 | 07:29 AM
Hotrod70d's Avatar
Hotrod70d
You should look at a more complete kit like a ready lift , they are cheap and give factory ride, it also allows all suspension components to be adjusted for a 2.5 lift, you can also get a 5" rear block and that won't put the lights in the trees. That's the kit I have "2.5 sst ", paid 325 for mine.
Old Apr 29, 2018 | 08:23 AM
orionife's Avatar
orionife
Thanks
Thanks for that. I understand that a load on a level truck would put lights in trees, which is why I mentioned the airbags. So if I understand 1.5" and 2" leave the bed a little higher and 2.5 inch completely levels it...this correct?
I will check my shock extension, and use that to see what I need.
Old Apr 29, 2018 | 08:44 AM
orionife's Avatar
orionife
Wouldn't a 5 inch block in the back defeat what you are trying to accomplish with a leveling kit? I am using airbags for loading.
brethren33
Feb 15, 2019 01:31 PM
Ian123
May 11, 2011 11:01 PM
gui88ford
2004 - 2008 F150
20
Feb 13, 2009 07:35 PM
maxnoodle
Mar 17, 2008 12:02 PM
Big Sweat
2004 - 2008 F150
Jun 2, 2007 06:22 PM
