Rear end swap compatibility
Old Mar 22, 2018 | 08:29 PM
Chase Borders's Avatar
Chase Borders
Hey yall, Chase here new to the forums but I'm in a sticky predicament.. I have a 09/86 f250 2wd single cab longbed (87 bodystyle) and a 7/87 f150 2wd single cab 2wd long bed.. is I have the "light duty " f250 351w 4bbl c6 with of course the 8 lug hubs and twin I beam front end on both trucks. Id like to swap the 1 wheel wonder rear end to the f250 rear end. How do I identify what rear end I have under my f250 and if the wheelbase and the year are the same, and the bracket for the suspension matches up. How hard should it be to swap rear axels? ...and the f150 has a double Axel shaft with a knuckle bearing in the middle and the f250 has a single Axel shaft.... I have the ability to swap if everything matches but I don' have the knowledge others have about these old trucks. Any advice?
Old Mar 22, 2018 | 09:05 PM
Conanski's Avatar
Conanski
No way your F150 has 8-lug wheels, it has a 5 bolt 8.8 under it while the F250 has a much bigger 8-lug 10.25.
mountain dewd
Jul 13, 2018 01:39 PM
derbyhunter5
Apr 13, 2015 02:37 PM
