Accessory Switches
Old Mar 21, 2018 | 10:08 AM
njdevil77's Avatar
njdevil77
Accessory Switches
I want to install a accessory fuse box and relays under the hood for some lighting. My question is where should I mount all the switched in the cab where I would not need to cut into my dash, but still be easy to reach. I have on my other truck for the fog lights just a switch under my ignition switch, but I have to lean over to use it while driving. Not fond of that. I was thinking of making some overhead console for them, but wanted to see if anyone here had a better idea.
Thanks
Old Mar 21, 2018 | 10:57 AM
Ug666's Avatar
Ug666
My 73 had a multitude of switches, connectors and a birds nest of wiring in the ash-tray location when I bought it. Likely still have to lean a bit for that though.
Old Mar 21, 2018 | 11:00 AM
Ug666's Avatar
Ug666
A thought off the top of my head (as someone tall-ish I want nothing to bang my head on) how about mounting a control panel below the drivers seat, near the seat slider lever
Old Mar 21, 2018 | 12:08 PM
JessyJ's Avatar
JessyJ
You need to find a spot where you don,t have to go looking for it while you are driving and texting. No seriously tho. How about a pillar pod, I,m pretty sure something is out there. How many switchs are you thinking?
Old Mar 21, 2018 | 12:26 PM
njdevil77's Avatar
njdevil77
I thought about both the ash tray and the A pillar. I use the slide in cup holder for the ash tray, so that is out. The A pillar is a good idea, I see stuff for newer trucks but nothing for Dents. I saw on another forum someone used a ford overhead console that looked pretty cool, even has three gauge cut outs. Part number is BC4Z-70519A70-B. I think I might try to find one of these. Just would need to figure out a mounting solution.
Old Mar 21, 2018 | 02:12 PM
HIO Silver's Avatar
HIO Silver
Here is where i put mine. The fog and driving lights are up front and the roof rack lights are divided inside and outside. The switch guard is a $2 drawer pull.
Old Mar 21, 2018 | 03:58 PM
njdevil77's Avatar
njdevil77
I would have used that spot but i have the a/c vent there. That seems like the best spot, wish i could find a way to put a shorter vent in that spot and put the switches under it. I only need a couple.
Old Mar 21, 2018 | 06:28 PM
HIO Silver's Avatar
HIO Silver
Ah... that was the one caveat since ya didn't post whether your rig was equipped with AC... must be nice!
I'd fab up a simple panel and mount it above the rear view mirror.... fish the wires up the A-pillar and along the front edge of the windshield/headliner.
Old Mar 21, 2018 | 11:33 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Fish tape the wiring up the A pillar and come up with a mini switch panel right in the corner of the cab by the visor mount area.
Mount them on the steering column by the tach, maybe on the t/s stalk like aftermarket cruise control. Do you have duel tanks? If not, what about to the right of the environmental control panel L/R slide bars. Like where the duel tank switch is? Any room in the steering column slip on metal cover like HIO has? If you have the metal one?
FYI anything hanging down on the lower part of the dash (from e brake release T handle and moving right...will stab a shin every time you get in in a hurry.
HIO to help ID and find your #1 important switch in the dark, (if they are not back lit) put a piece of surgical tubing with a 1/4" of over hang from the end of the switch. Makes for very easy to hand locate in the dark and not throw the switch. Old fly a helo in the dark (pre NVG's) control panel trick.
Old Mar 21, 2018 | 11:34 PM
mark-guiver's Avatar
mark-guiver
Above the mirror in a small switch panel is where I had the aux. light switches (4) in my old truck. Ran the wires up the A pillar just like HIO Silver said. Up out of the way and easy to reach.
Mark.
Old Mar 22, 2018 | 04:52 AM
ranger140892's Avatar
ranger140892
Grumpy goat
Maybe use foot dimmer switches for a couple of the accessories that you use most often. I did my bumper LED's that way.
Old Mar 22, 2018 | 06:18 AM
njdevil77's Avatar
njdevil77
Good suggestions, I like the foot dimmer idea for the bumper LED's. I think I will fab up a panel for either the center or over the visor like 77&79F250 suggested. I will use back lit switches so I can see them in the dark. Once I come up with a plan I will post the progress.
Thanks Guys, This forum ROCKS!!!! everyone is always willing share their thoughts. Gives you ideas and fills you in on errors they have made that you otherwise would never think of.
Old Mar 22, 2018 | 09:15 AM
Grampa jepp's Avatar
Grampa jepp
I like it! So much in fact, I just called my dealer to inquire about it.
Part number is good. He said, 'it's a build for Ford piece'. Available in 2-3weeks after ordering. He didn't have a listing that showed what this piece was made for, so we're guessing it's an aftermarket accessory that customer is supposed to retro fit into whatever vehicle they want it in. Finding one at a wrecker would be just pure fluke. $155 Canadian, plus shipping. Not too bad in my opinion. For my southern neighbors, probably quite a bit cheaper! Lol.
Old Mar 22, 2018 | 09:44 AM
njdevil77's Avatar
njdevil77
Yeah, I couldn't find it anywhere except Ford Parts sites, and could not find a vehicle that it was an OE item for. See them on sites down here for around $75.00. Thought they might have been made be for like an L8000 or a Wrecker. Not sure if I want to go that route yet, but it all depends on my skill is when I try to make something.
Old Mar 22, 2018 | 02:59 PM
meangreen92's Avatar
meangreen92
You could make a switch panel and clamp it to the steering column. Keep it all in one zip-code...
mlammert
Electrical Systems/Wiring
Dec 1, 2018 12:42 PM
Todd Fuller
Nov 5, 2014 12:48 PM
Hybris
1997 - 2003 F150
Dec 4, 2011 07:17 PM
Downriver Thunder
Apr 2, 2006 11:56 AM
acerockola77
May 10, 2003 10:27 PM
