Tension Bolt Broken Off
Old Mar 20, 2018 | 12:44 PM
KD90's Avatar
KD90
Anyone know how to fix a tensioner bolt that has broken off in the block? I’m traveling right now and just pulled over to check fluids to find belt almost off and tensioner pulling to one side. When i unscrewed it i found the bolt had broken off. This is what the stuck bolt looks like.
Old Mar 20, 2018 | 01:05 PM
joey2fords's Avatar
joey2fords
a set of sharp drill bits and a tap of the appropriate size when you are done drilling.
oh, and some patience !
good luck.
p.s. ... before all that you can try spinning it out with a hammer and a pointy punch ... you might get lucky.
Old Mar 20, 2018 | 01:06 PM
mrollings53's Avatar
mrollings53
What have you got for tools? It looks like maybe you could remove the accessory bracket to get better access to the bolt.
Old Mar 20, 2018 | 01:19 PM
wag53's Avatar
wag53
If you have to buy a drill bit, get a left hand bit and drill with that. Chances are, bolt will spin right out without further work.
fridgeddiesel
26
Sep 10, 2024 08:52 AM
giorgio.fo
Feb 20, 2014 11:57 PM
10bands
May 13, 2008 09:00 PM
ranger714
1983 - 2012 Ranger & B-Series
Mar 23, 2007 05:24 AM
tweakingit
Sep 29, 2003 07:34 PM
