Sponsored by: Real Truck
2000 7.3 issue
Old Mar 20, 2018 | 10:00 AM
Colorado350's Avatar
Colorado350
Originally Posted by Evan_P
If your getting smoke out the tailpipe after its already warmed up and your driving around it is not a glow plug issue. White/Gray smoke is more in line with unburned fuel on a diesel. A blue tint is more likely oil. Have you checked your oil level to see if you are loosing any oil?
X2 I miss spoke, blue is oil being burned, white/ grey fuel.
Granted this his is a commercial but explains smoke in a diesel rather well. Keep in mind our trucks are almost 20 years old they are going to smoke more than anything new on the road today. Have you done a buzz test on your injectors to make sure they're all firing?
Diesel Smoke tells YOU a Story…
Old Mar 20, 2018 | 10:31 AM
ManfredVonRichtofen's Avatar
ManfredVonRichtofen
Here is a test I done..i heard them all, but see what you think.
thanks
https://youtu.be/KDCxfKOk1Yo
Old Mar 20, 2018 | 04:00 PM
ManfredVonRichtofen
So I did a CCT test with the ForScan Lite app and this is what came up
=== Log ===
(OK) [16:52:48.109] KOER Cylinder Contribution Self Test has been started
(WARN) [16:53:50.607] Test completed, found DTCs: P0269, P0284, P0541, P0640
=== DTC ===
P0269 - Cylinder #3 Contribution/Balance
Diagnostic Trouble Code details
This DTC may be caused by :
Internal engine components
Possible causes are:
Fuel Injector
Valve train assembly
Compression rings
Refer to the vehicle Powertrain Control/Emissions Diagnosis (PC/ED) Manual for specific diagnostic steps.
Note: The A/C must be off when carrying out the KOER cylinder contribution test.
P0284 - Cylinder #8 Contribution/Balance
Follow the routines in the service manual to resolve the DTC listed.
P0541 - Manifold Intake Air Heater Circuit Low
Open circuit.
Short to Ground
Harness wiring
MIAH Relay
PCM
Inspect connectors for signs of damage, water ingress, corrosion, etc.
P0640 - Manifold Intake Air Heater Control Circuit Fault
Open circuit.
Short to Ground
Harness wiring
MIAH Relay
PCM
Old Mar 20, 2018 | 06:09 PM
ManfredVonRichtofen
Im thinking the CPS is the issue
Footy
16
Jun 5, 2013 06:41 AM
armyvet26
19
Oct 22, 2012 10:05 PM
bigk_54
17
Jul 31, 2010 08:45 PM
leftystar
13
Aug 2, 2008 10:07 AM
pimpedrsrage
27
Jul 5, 2006 05:56 AM
