Fully charged battery, battery terminals wire-brushed clean, all cable connections (positive and negative) wire-brushed clean (including at the starter motor).
This YouTube video shows the way to test a starter relay by momentarily shorting the two large terminals.
Making this test identifies the relay as the cause of the no-crank condition.
I removed the relay and observe a printed warning on the black plastic housing:
CAUTION
REPLACE WITH SPECIFIED FORD SERVICE
PART ONLY. OTHER PARTS MAY DAMAGE
THE ENGINE ELECTRONIC CONTROL UNIT.
Is this merely "scare language?" Must I buy a replacement from the dealer or may I safely use the aftermarket relay sold by local vendors such as AutoZone?
You also need to jump the battery terminal to the little post on the solenoid. If it turns over then you have other issues bad neutral start switch, clutch interlock, or ignition switch.
Yes. Did that, got the same loud CLICK (but no crank) as when the ignition key is turned to START. I'm convinced that the relay is faulty but was startled to read that stern warning. Thanks to all... I will replace that relay.
Last time I was in a auto salvage yard I got a hand full of those relays off newer models wrecked Fords for cheap ( Ranger,, Explorer ,,, Mustang or whatever ),,,they were all OEM ford motorcraft from factory and are handy to have around,,,I also found several cars and trucks that the dash was apart on and got a hand full of dash light bulbs and all of it was only a few bucks
Advance Auto has replacement relays with a slew of customer reviews saying "Bad", "Terrible", "Junk", "Don't buy this", and "Stay away." Discouraged by these reviews, I resorted to eBay and bought one for $9, shipping included. Installation was easy and now the truck cranks eagerly, every time.
Just for fun, I performed an "educational autopsy" on the failed relay. Sure enough, one of the two high-current "buttons" was burned black!
Thanks for the advice. This story has a happy ending!
Daniel B. Martin
Good find, fix, feedback & to hear your on the road again!!!
