Power Serve question
Old Mar 19, 2018 | 10:33 AM
MG250's Avatar
MG250
I use PS white in the winter and plug my truck in when it's cold. The challenge is when the temp is below -10, even with the truck plugged in, I get some gelling.
The gelling is in the rear fuel filter area.
So the question - when it's that cold, and I already put in at least double the PS white amount at the diesel fill up, can you put in some PS red during diesel fill up to potentially negate any gelling in the fuel filter or will that cause fuel system issues prematurely?,
Old Mar 19, 2018 | 12:34 PM
Braggs's Avatar
Braggs
Plugging the truck in (block heater, et al) has nothing to do with the fuel gelling. Make sure you use the "winter" treatment fuel-to-additive ratio (16 oz per 20 gallons) listed on their website. Using the +0F ratio (16 oz per 40 gallons) won't cut it. See their website. If this supplement is not providing the anti-gel performance you are expecting, it might be necessary to switch to a different additive.
https://powerservice.com/psp_product...-boost/#tabs-3
Old Mar 29, 2018 | 04:09 PM
Deanmc's Avatar
Deanmc
Are you not able to buy winter or arctic grade fuel in your area?
white Buffalo
37
Jan 26, 2014 11:06 PM
Yahiko
Sep 24, 2012 07:28 AM
PrinceValium
6.7L Power Stroke Diesel
Jan 10, 2012 11:43 AM
buckmasters
Oct 30, 2011 09:05 AM
danonbar
Jan 22, 2005 10:11 PM
