startup clatter.
Old Mar 19, 2018 | 05:19 AM
Im50fast's Avatar
Im50fast
startup clatter.
not sure if you folks know my “story” but I recently got a 2nd van with 4.6 and 225,000 miles. I drove it a few hundred miles at first, but since then my employee has been using it, so I’ve been out of the loop of its characteristics.
Im a V10 guy; lots of knowledge and experience there. (Almost five years and 220,000miles of direct experience). But never had a 4.6 before.
Yesterday I wanted to check fluids and stuff and when I cranked the engine it struck me kind of funny. Some noise for a few seconds upon starting. I don’t want to describe it or label it because that’s the point of me asking you. It sounded like when you start a car for the first time after it sat for a couple days. I want to say valvetrain but I actually don’t know. But The van had only been still for an hour or two.
I know nothing about the 4.6. But I’ve read on FTE about cam phasers or timing chain guides or some other oil pressure related items. I think I’ve read about these regarding the 3 valve engines though. its all very murky.
What do do you think? Or lead me the right direction please.
Old Mar 19, 2018 | 07:33 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
Refresh my memory, what year is it?
Old Mar 19, 2018 | 10:22 AM
alloro's Avatar
alloro
Make a video getting as close to the source of the noise as possible. Then post it to YouTube and post the link to the video here. It helps a lot when we can hear the sound.
Old Mar 19, 2018 | 03:07 PM
Im50fast's Avatar
Im50fast
2005 e150 cargo van
Old Mar 19, 2018 | 05:23 PM
krewat's Avatar
krewat
If it's a two-valve engine, there are no cam phasors to worry about.
Check the heat shields on the exhaust. And if you can, make a video like alloro said.
Old Mar 19, 2018 | 09:37 PM
z31freakify's Avatar
z31freakify
Its probably bad timing chain guides or a timing chain tensioner loosing prime.
Old Mar 20, 2018 | 04:04 AM
Im50fast's Avatar
Im50fast
teachme more
Old Mar 20, 2018 | 09:14 AM
z31freakify
It has the same timing system like your V10, so if the guides are worn down or missing pieces the chain will slap around untill the tensioner compensates for the slack, or if the timing chain tensioner is leaking or damaged, untill you reach oil pressure it will make the tensioner guides loose making the chain to slap around.
ps if the guides has missing pieces its wise to remove the oil pan to get those broken pieces out so that they wont compromise the oil pick up tube flow and giving you low oil pressure.
Old Mar 21, 2018 | 04:46 AM
Im50fast's Avatar
Im50fast
interesting
and this is common?
And it matches my symptoms?
Old Mar 21, 2018 | 04:34 PM
z31freakify
Its common with vehicles that didnt get the oil change often.
Old Mar 21, 2018 | 07:58 PM
Im50fast's Avatar
Im50fast
oh man that’s me. My average is probably 10,000 miles
wait no. I’m thinking of my V10 van.
This thread is about my “new” 4.6 van. I don’t know it’s history.
Old Mar 21, 2018 | 08:12 PM
z31freakify
If you take the oil fill cap off and shine a light inside you can see if the engine got the oil change often or not, a tarnished or darken colored cam and heads is a good indication of the oil not getting changed often, a clean light brown to aluminum colored head is a good indication of the oil got changed often.
Unfortunately in order to fixing is removal of timing cover and valve covers and the replacing them timing is crucial when putting the timing chains so if you decide to fix it yourself make sute you do it right.
Old Mar 22, 2018 | 04:25 AM
Im50fast's Avatar
Im50fast
ah, actually no. My oil fill tube is about two feet long. It’s a van. But your point remains.
And no I wouldn’t even consider engine repairs like that. I have no experience with overhead cam engines timing chains.
Thanks for the input
Old Mar 22, 2018 | 03:00 PM
z31freakify
Oh thats right its an E series, a quick look at the inside of oil filter housing/ cooler should reveal if it was changed often.
Old Mar 22, 2018 | 04:32 PM
z31freakify
Also forgot to mention what brand of oil filter does it have now? And what weight oil and how old is it? As these can also lead to your clatter when started.
michaellong
13
May 10, 2018 08:43 PM
Greg Rogers
Modular V8 (4.6L, 5.4L)
Mar 5, 2017 12:32 PM
MommieRed
34
Dec 16, 2011 03:07 PM
spnrgy
Dec 8, 2004 05:05 PM
sinjin
Sep 26, 2003 07:29 PM
