Knock in 02 4.6 engine.
Old Nov 22, 2016 | 06:43 PM
Greg Rogers's Avatar
Greg Rogers
Hi Folks. I just bought a very clean 02 E150 Starcraft conversion van. It has 159,000 miles on it. It has a tick nose that is very constant. The seller told me about it, in fact he said he bought it from the 2nd owner who said it has made this noise as long as he had it. It was supposedly traded in or sold by the 1st owner shortly after the noise started. So the noise has been there for a long time- never getting worse or better. The second owner drove it from Mi to Florida and Texas and then the 3rd owner drove it across country (about 7000 miles). Anyway I was pretty sure it was something simple so I bought it. I know its not a exhaust leak or ready to blow out plugs. Its a constant tick/rap from the center of the engine. I removed the right valve cover and started the engine and can see all is fine there, no noise at all from there. Now I am worried that it might be a wrist pin which would explain why its so hard to pinpoint. You guys got any ideas? Thanks, Greg
Old Nov 23, 2016 | 05:45 PM
Greg Rogers
Well today I pulled the wires to the individual coils one at a time and determined the noise is on the #1 cylinder. The tick changes alot when #1 is disabled. Now I'm really worried it is a wrist pin or piston. Going to pull the oil pan tomarrow. Boy are things tight on this modular engine in a van!!
Old Nov 24, 2016 | 07:59 PM
Greg Rogers
Anyone have any ideas??
Old Nov 25, 2016 | 11:42 AM
z31freakify's Avatar
z31freakify
Might be a sticky lifter, run some seafoam on the oil and see if it goes away.
Old Nov 25, 2016 | 09:42 PM
wtroger's Avatar
wtroger
These are known to have an issue with piston slap. It's up to you but if it has been running for a long time like this then I would just drive it.
Old Feb 27, 2017 | 06:49 AM
Greg Rogers
I forgot I started this thread. I have found out what the problem was. Some one changed the spark plugs and dropped a 1/4" socket down the #1 spark plug hole!!! It ended up cracking the piston and put a perfect indentation of the bottom of socket on the piston and a indentation of the top of socket in the head. I think it was the small socket that was used to take off the coils. I think it was a accident and as soon as they tried to start it it hit once and stopped. Then I think they took the spark plug out and fished it out of the plug hole with a magnet. I put in a used piston/rod along w/ new gaskets chains,etc. Now runs great- no noise. Previous owner wanted me to call him when I got it figured out so I did. He said that made sense since the knock started after he had new plugs installed... Wow...
Old Feb 27, 2017 | 05:24 PM
Greg Rogers
Some pics of the piston. Can you believe it??
Old Mar 1, 2017 | 06:58 AM
enriched&beyound's Avatar
enriched&beyound
wow...yep that'll do it
Old Mar 5, 2017 | 12:32 PM
alloro's Avatar
alloro
How was the wall of the cylinder, any damage?
NICKSAN
Apr 16, 2018 09:33 PM
Hotairjunkie
Modular V10 (6.8l)
Jun 2, 2012 03:44 AM
thomas lapp
Mar 24, 2009 05:37 AM
mikeil888
Sep 27, 2002 01:28 PM
ScottsF150
1997 - 2003 F150
Jul 14, 2001 11:12 PM
