'92 E4OD in a '93?
Old Mar 18, 2018 | 11:48 PM
InsanePyro's Avatar
InsanePyro
'92 E4OD in a '93?
Will a E4OD from a F150 with the build date of 12/92 work in a '93 Bronco? I don't know the build date off the topic of my head for the Bronco.
Old Mar 19, 2018 | 12:09 AM
mrollings53's Avatar
mrollings53
As long as they have the same bellhousing, output, and the Bronco already had an E4OD to begin with.
Old Mar 19, 2018 | 12:52 AM
InsanePyro's Avatar
InsanePyro
Oh yeah for sure, at most the tcase will have to be swapped onto the "new" trans, other then that they're identical I think. I was more worried about the computer aspect of it. I have no clue what years Ford changed stuff (if it at all). The only real experience I have with electronic transmission is Chevys and for a while they were changing stuff yearly.
Old Mar 19, 2018 | 07:16 AM
mrollings53
There was an electrical change in '94 or '95. Keeping the transmission range sensor, and solenoid pack with the vehicle they came out of is the solution. The electrical connectors are physically different between the change, so a newer style part wont fit the older wiring harness, and vice versa.
Old Mar 19, 2018 | 07:36 AM
subford's Avatar
subford
A 12/92 would have been in a 1993 anyway.
GIO23
Apr 28, 2010 06:51 AM
unclemyke
May 3, 2009 11:29 AM
Darin1
Aug 23, 2008 06:11 PM
