U-joint part numbers
Old Mar 17, 2018 | 07:52 AM
jcp8587's Avatar
jcp8587
I have a 2001 f-250 7.3L 4wd. I am in the process of replacing the front axle u-joints and the drive shaft u-joints. I have a single piece drive shaft ( no carrier bearing) with two u-joints. I purchased the Spicer 1410 series u-joint for the rear drive shaft and this fit fine. For the front of the drive shaft u-joint I purchased and installed the Spicer 1350 series u-joint. After installing it I noticed the u-joint can slide up and down, which I dont think it should be able to do? It seems like I may have the wrong u-joint size for the front drive shaft and upon further research it looks like the Spicer 1350 u-joint is for the two piece drive shaft. Does the single piece drive shaft have a different u-joint size than the two piece? If so does anyone know the proper size. I tried researching this and have had little luck. Any help would be appreciated. I attached pictures as well.
Old Mar 17, 2018 | 11:26 AM
crop harvester's Avatar
crop harvester
I know this is poor answer,If You can find a Auto Parts Person with experience,They can spec out U-joint by dimensions from Your old one.Otherwise bump to top.
Old Mar 19, 2018 | 02:20 PM
brian42's Avatar
brian42
Veteran: Navy
Here's the Spicer parts list for our driveline:
Looks like the 1350 is for the front driveshaft. Depending on if you have a Dana 50 or 60 will determine if you need a 1350 or SPL55-3x for the axle shafts.
68horses
Dec 21, 2014 07:11 PM
keyul
Jun 17, 2010 09:41 PM
postalxj
Dec 19, 2009 01:10 PM
kupiec20
Oct 12, 2009 11:07 PM
79f-250custom
Jun 8, 2009 10:04 PM
