Won't start
Old Mar 16, 2018 | 12:10 AM
Boomer51's Avatar
Boomer51
Won't start
Have a 1951 F1 V8. Converted to 12 volt. Just replaced the generator and resistor. Polarized correctly. Battery charged, but still will not start; won't even turn over. Did I toast my starter in this process? Any suggestions. Appreciate it.
Old Mar 16, 2018 | 01:58 AM
TitusDH's Avatar
TitusDH
Highly unlikely. A 6V starter can stand the occasional 12V burst many times. Most People even do not bother to change the 6V starter when converting to 12V. Maybe bad battery contacts? And you might try to touch with 12V directly to the starter bypassing the Solenoid and see if it tries to engage at all.
Old Mar 16, 2018 | 09:25 AM
ALBUQ F-1's Avatar
ALBUQ F-1
Can you turn the engine by hand? Is the starter trying to turn it?
Old Mar 16, 2018 | 01:48 PM
Jafo56's Avatar
Jafo56
Check your points....I had that happen after it was sitting ...stupid me who is fairly good auto mechanic...totally overlooked it and forgot about the points...I am so used to the new stuff firing right up....
Old Mar 16, 2018 | 01:51 PM
Jafo56's Avatar
Jafo56
Sorry disregard.......I tried to delete it....
Old Mar 16, 2018 | 04:12 PM
petemcl's Avatar
petemcl
I have a used and a new starter that will fit your truck that I will sell at a good price. Send me a PM if you need one of them.
Old Mar 16, 2018 | 04:34 PM
Boomer51's Avatar
Boomer51
These are all great suggestions that I will try over the weekend. Thank you all for the input; will report back hopefully with a success story.
Old Mar 17, 2018 | 01:45 AM
Fomoko1's Avatar
Fomoko1
I have a 53 M100 flat head powered on 12 volts and had the starter lock up on the flywheel, it didn`t make a sound and wouldn`t turn over. I loosened the starter and had a hard time to get it off the flywheel but once I did and put it back on the engine fired right up. 6 v starters lead a pretty hard life on spinning on 12 v.
Armedsvt
27
Jun 13, 2015 02:38 AM
sdetweil
13
Sep 20, 2010 12:32 AM
scbronco
Dec 23, 2007 08:55 AM
quad4x4
Jan 3, 2007 01:10 AM
saxtonj
Jan 13, 2005 06:58 PM
