Sponsored by: Auxito
More HP?
Old Mar 15, 2018 | 05:21 PM
WD Ray's Avatar
WD Ray
More HP?
Hello, I'm new to this forum,and am not very mechanical savvy. I have a 2000 F150 4x2, with 112k miles, ext cab,auto trans,3.55 gear (8.8 axle) , 4.6 V8.
This coming up Saturday I'm having my 3.55 ring and pinion swapped out for a 4.10 ring and pinion.
The only thing that I have done to my truck performance related is have true dual exhaust done along with Borla Pro XS Mufflers installed.
What can I do as low budget as possible to gain at minimum 40-50 hp,of course along with additional torque as well.
I will say that I do tow a utility trailer approx 3-4 day per week in town,and the max load weight including trailer is approx 1,700 lbs.
I would be grateful for your insight!
Old Mar 15, 2018 | 06:33 PM
steve(ill)'s Avatar
steve(ill)
you cant gain 40 HP without spending some BIG MONEY... Engine displacement is a CONSTANT.. Adding fuel or air does nothing since the RATIO has to be a fixed value. To get real HP you need more displacement, more RPM ( which you may get with the higher gear ratio) , turbo ( more air in same displacement)...................... air filters, new mufflers, even a tuner will not do much more than a couple HP.
Old Mar 15, 2018 | 06:46 PM
WD Ray's Avatar
WD Ray
Thanks for your reply. What kind of money for 40 extra HP?
How about even 25HP extra?
Old Mar 15, 2018 | 08:52 PM
Bluegrass 7's Avatar
Bluegrass 7
You don't get those kinds of power increases with cheap easy modifications.
For perspective, a positive displacement super charge offers about 10 HP per pound of boost.
If you want 50 HP it would take 5 PSI of boost.
A super charger install is close to $5000 +/- and reprograming the computer hoping the old engine and trans can take the boost and heavy foot..
Why to you want this much for a truck application that pulls a utility trailer?
You might just wrap that trailer around you neck.
Good luck.
Old Mar 15, 2018 | 10:07 PM
WD Ray's Avatar
WD Ray
I'll use the extra power when i'm not towing the trailer. lol
Old Mar 16, 2018 | 08:20 AM
Mickey Bitsko's Avatar
Mickey Bitsko
A lower r&p cheapest way.
Mickey
Old Mar 16, 2018 | 11:45 AM
WD Ray's Avatar
WD Ray
Mickey
What is an R&P ?
Old Mar 16, 2018 | 11:51 AM
Mickey Bitsko
Ring and pinion
Old Mar 16, 2018 | 11:52 AM
WD Ray's Avatar
WD Ray
Thank you Sir.
Old Mar 16, 2018 | 01:58 PM
Mickey Bitsko
Not sure you can get a 4:30 ring and pinion for an 8.8, might be worth looking into. If you aren't interested in breaking the land speed record, you could go to 4:56 and tow any recommended weight you wanted
Mickey
Old Mar 16, 2018 | 02:37 PM
WD Ray's Avatar
WD Ray
Mickey
I want to keep as much top end as I can. I sometimes hit the interstate,like 1 time per month to visit family. It's a 3 hr round trip. Something I've read a little about is a flex a lite electric fan,and also the pulleys made by BBK. Not as much to gain HP by having these items but allowing the engine to not work as hard.
Old Mar 16, 2018 | 02:59 PM
Mickey Bitsko
You might Google a calculation chart
put in your tire size, stock r&p , final drive ratio on the I assume 4r70. Then play with the desired r&p , might find not that big a deal.
Mickey
Old Mar 16, 2018 | 03:27 PM
WD Ray's Avatar
WD Ray
Mickey
I can't seem to figure all that out. Just when I thought I did the numbers don't reflect what I think is correct.
I currenty have auto trans., 3.55 8.8 axle, my tires are
245/70R16 106T 245/70R16 106T
Old Mar 16, 2018 | 03:53 PM
Mickey Bitsko
Call Randy's ring and pinion or Summit Racing, and ask to talk to technical support .
Just tell them what you're trying to accomplish.
Mickey
Old Mar 16, 2018 | 05:14 PM
steve(ill)'s Avatar
steve(ill)
your present ratio is 3.55 ............ lets say you are traveling 70 MPH and your motor speed is 2000 RPM..... if you change to 4.10 gears that is 4.10 - 3.55 = .55 or .............. .55/ 3.55 = about 15% .............. 15% of 2000 rpm is 300 rpm ......... so if you put in 4.10 gears, at 70 MPH you would be running 2300 RPM, not 2000. ............... that moves you further up the HP curve and your have more power at 70 MPH ............ like downshifting one gear.
