Dual Front Shocks?
Old Mar 15, 2018 | 02:22 PM
mcs1056's Avatar
mcs1056
Dual Front Shocks?
My '70 LWB, 390/4 spd. Custom has four front shocks. Is this common? Is it to help with the weight of the FE?
Old Mar 15, 2018 | 03:29 PM
Brian1971f100's Avatar
Brian1971f100
My 71 f100 2wd swb has holes in the spring tower for a 2nd pair of shocks. But no place to bolt the shock below. Is it 4wd? I'm figuring its got to do with the package that came on it from the factory.
Old Mar 15, 2018 | 03:57 PM
RichS2659's Avatar
RichS2659
If 2wd, those are aftermarket lower mounts from the late '70's/80's for the pre-runner/Baja race craze. IIRC Ford did offer dual shocks for 78-79 F-150/Bronco 4wd's.
Old Mar 15, 2018 | 04:02 PM
Brian1971f100
My 94 bronco has dual front shocks
Old Mar 16, 2018 | 10:24 PM
SteveJH's Avatar
SteveJH
I've got a 69 crew cab and it's got dual shocks. Got another question too:
Can a truck set up this way take the OEM Sway bar? Or does the front shock mount get in the way of the c-cup the bar mounts to?
Old Mar 17, 2018 | 10:47 AM
willowbilly3's Avatar
willowbilly3
Depends on the sway bar I suppose. If you have this style, no problem (except finding headers.
Old Mar 17, 2018 | 12:55 PM
Millam's Avatar
Millam
I'm pretty sure that is due to the fact that both sides are the same. This allowed the factory workers to just grab a piece and put it on whatever side they were working that day.
It wouldn't be that difficult to fangle up the axle mount brackets. I would be interested in seeing how the forward axle mounts were done.
Old Mar 17, 2018 | 01:31 PM
Brian1971f100
Good point. Hadn't thought about that.
351Cleveland C4
1978 - 1996 Big Bronco
Sep 10, 2014 11:32 PM
crazy96863
Mar 17, 2012 02:15 AM
Growl60
Jun 19, 2010 03:26 AM
timbersteel
Oct 12, 2007 08:34 AM
Torque1st
Nov 27, 2002 10:32 AM
