See below
Old Mar 15, 2018 | 02:34 AM
darknight's Avatar
darknight
See below
so I’m in a good predicament of having two good trucks to choose from. I tow a 39 ft toy hauler for work/ living and daily drive my truck. I’m mobile with work right now and drive 2000 miles or so a month. I have a 2001 f350 dually v10, all set up, flatbed, hitch, ranch hand etc. 4.30 gears
I also have a 2004.5 Cummins 2500 Cclb 6spd, b&w companion hitch
both trucks have excellent tires brakes etc, and the dodge will be getting air bags. Both trucks are overloaded technically
I’m headed back to where my trailer is (currently visiting family considering swapping trucks to take back) over 1000 miles away. I can’t just hook up and try it out.
So do I stick with the v10 getting 6mpg towing and 9 unloaded or opt for the Cummins non dually for ??? Towing and 17 plus unloaded (17.03 hand calc today)
thank you for any insight
Old Mar 15, 2018 | 02:36 AM
darknight's Avatar
darknight
I should clarify that roughly 30% of my driving is towing
Old Mar 15, 2018 | 09:37 AM
ibdagriz's Avatar
ibdagriz
I'm thinking the 04 will be overloaded on the TH by a bunch, but I'm not positive.
Griz
Old Mar 15, 2018 | 11:44 AM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
Griz is right, without know the specifications of the trailer, it is hard to say anything other than you should stick with the dually.
Old Mar 15, 2018 | 03:39 PM
wrvond's Avatar
wrvond
Neither truck is perfect for your needs/wants. But I'd say the dually is probably the safest.
Old Mar 15, 2018 | 08:06 PM
senix's Avatar
senix
DRW is the better choice right now.
Old Apr 10, 2018 | 10:16 PM
darknight's Avatar
darknight
Well as you’d have it I drove the Cummins back to the trailer to really figure out what I want. It’s awesome to have the mileage and power (stock) I’m getting 17 to 18.9 unloaded hand calculated. I’ve yet to tow the big trailer any real distance but towing roughly 4K pounds I was getting 14 to 15mpg. All my fuel savings are slowly going with things like a radiator that went out, carrier bearing, and now the clutch has maybe a couple weeks left in its life. I’m thinking about selling the Cummins and just driving the dually, enjoying the boring reliability. I’m thinking about adding a tune from 5star and a y pipe to give the v10 some more power. Thank you for your input, I’ll see if I can limp the dodge home to fix it there, laying in the dirt working on it sucks
AJCASSARO
Modular V10 (6.8l)
Jan 23, 2018 12:38 PM
Wolfboro
Modular V10 (6.8l)
Oct 11, 2011 07:10 AM
pooldude
All Things Towing
Apr 9, 2008 08:27 PM
kingquad
Modular V10 (6.8l)
Feb 12, 2008 10:54 AM
geezee
Feb 11, 2004 05:13 PM
