I have a question with my 6.4 liter serial number is it possible to identify it with my VIN number of my truck? Can I find out if that motor belongs to my truck pair it together?
The serial number for a 6.4L Power Stroke engine is located on a half moon shaped section of the engine block on the driver's side, rear of the engine. A sticker that is applied during production will need to be removed in order to see the serial number. The first two digits will read "6.4", followed by a four digit manufacturing designator (HU2Y for engines built in Huntsville, AL and HU2U for engines built in Indianapolis, IN), and the final 7 digits are the sequential build number. The same information is also available on the front of the engine, on a sticker mounted on the EGR cooler. Here you will find the plant at which the engine was produced as well as the build number (build number is the last 7 digits of the number posted just above the lower bar code).
So I so I guess I'm asking if I can identify my motor to my vehicle VIN number. I received my truck back in pieces from an auto mechanic in town and I'm trying to figure out if he gave me my block back the block that was matched up with my truck from the factory?
