Sponsored by: Real Truck
Need help rough idol
Old Mar 14, 2018 | 01:07 AM
ScumFord's Avatar
ScumFord
2000 f250 5.4 vin letter “L” 229,xxx miles 2wd. Problem. Low idol under load. Truck was given to me not running and 2 flat tires. Misfire cyl 5. TB completely coated in grim. Dirty MAF. Clogged cat. Deteriorated muffler. IAC snorkel hose loose. Pvc not connected.
I now have the truck running. Put Toto M/T’s 33’s. New plugs ( ngk’s ) -cyl 7 plug soaked in oil.- new coil pack cyl 5. Removal of cat. Cleaned TB and seafoamed thru booster, oil, & fuel. Cleaned mass (even replaced with another used cleaned one.
Idol is still low under load (500-700 rpm). No code light on as of right now. But did get a p0141 bank 1 #2. So the trucks running Ritch and rough idol. Where should I start next?
Thanks for all the help
V10man
Jun 15, 2018 02:45 PM
jkait1982
2004 - 2008 F150
Mar 3, 2014 05:18 PM
roverjoe
Modular V8 (4.6L, 5.4L)
Mar 22, 2012 05:28 PM
nfrancis1
Nov 19, 2009 10:11 PM
Summithi
Mar 18, 2006 08:14 AM
