Cab weight
Old Mar 13, 2018 | 10:21 AM
JBrian's Avatar
JBrian
Cab weight
Hi, what does a bare cab weigh off a 67? I am close to getting ready to separate the cab from the frame and was curious how many people I would need? I have a winch on the ceiling that is used to pull the top off of my wife's 4 door wrangler, but I fear that A) the cab will weigh more and B) that it will mess up the cab lifting it that way.
Thanks.
Old Mar 13, 2018 | 10:32 AM
gittinwidit's Avatar
gittinwidit
Use nylon straps with your winch to not mess up the cab or 4 people period. But if you do a search, you will find a lot of people favor using an engine hoist hooked to or below the floor accessed through a door. And it evidently works just fine.
I have a wrecker (basically same as a winch from ceiling) and I just weave nylon straps through the door windows. But if you don't have access through the front windshield and back glass, you will need to remove the trans cover to weave one around the cab to keep it from tipping forward or backward for there's not a great way to keep the straps stable just running long ways from side to side lifting straight up.
Old Mar 13, 2018 | 11:36 AM
mrpotatohead's Avatar
mrpotatohead
My guess is about 300 to 400.
Old Mar 13, 2018 | 03:09 PM
HIO Silver's Avatar
HIO Silver
Thanks.
Mike Zeros weight the cab of a Dent as well as other body parts. Seek the link in the Tech Info Compilation.
Old Mar 14, 2018 | 08:57 AM
Brian1971f100's Avatar
Brian1971f100
Are the doors and glass still attached? I think 2 healthy guys could do it. Be much better with 4. If the doors, glass and seat are out cab weighs about 350.
ClassicKidNick
Jun 7, 2021 11:31 PM
SCD
Oct 4, 2010 05:46 PM
BarryMc
Apr 18, 2008 08:15 AM
create
Jun 10, 2006 06:57 PM
Rosati
May 16, 2002 10:11 AM
