removing 1 leaf spring from pack
Old Mar 12, 2018 | 08:17 PM
Justforfishing's Avatar
Justforfishing
installed some new front pro-comp 4" Super Duty lift springs.
They are slightly taller than I was wanting. I know they may settle down slightly once i drive it, which I may see how they look after a little driving. . I Read where i would remove the second spring in the pack (military wrap) and it would maybe lower an 1"
Does this have any long term negative effect? WIll the spring be more likely to sag over time or break?
Old Mar 12, 2018 | 08:30 PM
PA74F250's Avatar
PA74F250
I would drive it awhile before you consider that. I know my skyjackers went down a noticeable amount after they settled in.
Old Mar 12, 2018 | 08:48 PM
somethingclever's Avatar
somethingclever
If you want it to come down 1" then I would remove a spring....either the second or third one down...
My experience is about .25-.5" drop max after many miles.
I just added a second spring to a new pack and gained .5".
Old Mar 13, 2018 | 06:57 PM
Justforfishing
thanks for the replies
Going to wait and see how much it settles down. Hopefully it drops. Haven't even drove it yet, but hoping the weight if the cummins will help
Old Mar 13, 2018 | 09:56 PM
skyhawc's Avatar
skyhawc
It can be a game of trial and error. I've done a lot of leaf-spring tuning, building numerous Jeeps with non-factory leaf springs from other vehicles. New springs will settle some, but not a whole lot, unless you're adding more weight from aftermarket bumpers, winches, bigger motors, etc... As to which spring to remove, I'd have to be more familiar with the exact spring you're using, such as number of individual leafs in the pack, and leaf thickness...
Another thing to note, lift springs, since they have a larger arch than factory sprints, are longer than stock, by removing leaf(s) you can throw off your shackle angles. But again there's other variables at play with shackle angles.
Old Mar 14, 2018 | 02:56 AM
buckin69bronco's Avatar
buckin69bronco
I removed the last 2 leafs of my super duty springs. I bought the springs off cl but they were new so I don't know how much lift they were suppose to be. With the two leafs remove I have 3 left and it's level with my rear shackle flip and stock rear springs (guessing 3" of lift)
i did have the issue that skyhawc mentioned. The springs got long after removing leafs and that moved the axle back. I fixed this by moving the front hanger about 1.5" forward to go along with the 2" longer front shackles that sd spring require.
Frisbeekev
Aug 26, 2018 06:32 PM
rottov
Feb 15, 2018 01:55 PM
GM4WALLS
Jan 9, 2016 05:36 PM
DonMurray
1983 - 2012 Ranger & B-Series
Oct 23, 2009 05:04 PM
77hiboyboy
17
Jun 30, 2008 02:46 PM
