Steering gear boxes
Old Mar 12, 2018 | 05:52 AM
theoldbither's Avatar
theoldbither
Steering gear boxes
Is there a difference between 2wd and 4 wd steering gear boxes
Old Mar 12, 2018 | 07:34 PM
fe390pc's Avatar
fe390pc
Yes there is also a difference between f100 and F250 4x4 steering boxes.
Old Mar 13, 2018 | 03:55 AM
theoldbither
Thanks. That really helps my search.
Old Mar 13, 2018 | 04:24 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by theoldbither
Is there a difference between 2WD and 4WD steering gear boxes? Yes.
C5TZ-3504-D .. Manual Steering Gear Box: 1965/72 F100/250 2WD; 1967/72 F350.
C7TZ-3504-M .. Manual Steering Gear Box: 1966/75 F100 4WD & 1975 F150 4WD (also used with Power Assist P/S on 1973/75's).
C7TZ-3504-A .. Manual Steering Gear Box: 1967/75 F250 4WD (also used with Power Assist P/S on 1973/75's).
Old Mar 13, 2018 | 05:47 PM
theoldbither
Steering gear box
actually the body is on a 70 f250 4x4 chassis and my goal is to convert to power steering. The gear box is from the the 70.
Old Mar 13, 2018 | 09:25 PM
RichS2659's Avatar
RichS2659
You have several choices for a highboy PS.
1. Easiest would be a PS box from a 77.5-79 F-250 from JY, or a semi-rebuilt one from a parts store, if you can find one. $$$
2. Next easiest is the same box from Red Head Steering which thoroughly rebuilds it, and adds bearings where needed that Ford/Saginaw didn't originally provide. More $$$, but do it only once.
3. A PS kit from Benchworks with everything needed which you install. $$$$
4. Fabricate your own with whatever PS box you can find besides the above. $$$$
The PS assist systems which use the manual box are junk with very little parts availability.
Old Mar 14, 2018 | 12:05 AM
theoldbither
Steering gear box.
Thanks. Was thinking about buying a parts truck . Just didn't want to buy the wrong truck. Now have to convince my honey that my free truck is worth a another truck.
Old Mar 14, 2018 | 03:32 AM
GaryKip's Avatar
GaryKip
Just tell her "It's all about safety".
TheGermanGuy
21
Nov 26, 2016 07:30 AM
SharkyJ
WTB - Parts & other
Feb 2, 2016 06:22 PM
brenjimin
13
Jul 27, 2012 09:30 PM
400Nut
Aug 30, 2006 09:37 PM
