Help, 1948 front panel alignment
Old Mar 9, 2018 | 12:23 PM
mod22's Avatar
mod22
Trying to align front sheet metal but when I go to tighten fenders to the upper grill it doesn't want to tighten without bending metal around bolt holes. Any tips??
Old Mar 9, 2018 | 01:17 PM
underthebridgejim's Avatar
underthebridgejim
FTE fan
I found this link to a prior thread on this subject. It may prove helpful,..https://www.ford-trucks.com/forums/1...procedure.html Update, I just realized it is for a F100 not an F1, Sorry but I'm sure someone with more knowledge will chime in soon. Meanwhile Ill keep looking.
Old Mar 9, 2018 | 01:51 PM
bhalemail's Avatar
bhalemail
Are those upper front fenders re-pops? (ie new)
I'm at that point in the next couple weeks so i can speak first hand on how to adjust but just thinking about it and looking at your pictures it looks as thought the back of the upper grill panel is pretty tight/close to the fender and it spreads the further out you come. I don't know how much of a difference it would make but do you have the cowl lacing between the fender and cab/cowl in place? That might push the back of the front fenders out a little and allow the front gap to close a little. The holes in my inner fender panels for mounting are definately larger than they need to be. perhaps this is for some adjustment (in and out/side to side). Do yo have front grill attached to the fender around the headlight openings? I can't recall without looking at mine but if those screw holes are slotted perhaps loosening them a little would allow the fender to adjust inwards without binding the metal. Not sure i'm explaining it correctly or not but if the fender can't go in because it's attached to the grille then the only thing that would happen is the metal would pull at the fastener.
Sorry i'm not much better help but I'll be watching this thread closely so please keep us up to date with your progress. Many on here have done this so i'm sure they will be along shortly to offer some "real" help. Once i get home and out to the garage i'll take a look at mine and see what i can find that would allow the fender to adjust
Old Mar 9, 2018 | 04:17 PM
mod22's Avatar
mod22
Thanks for trying to help. Some info in there was still helpful.
Old Mar 9, 2018 | 04:36 PM
mod22's Avatar
mod22
The fenders are repop steel. Seem to fit well besides this. No bolts around headlight. Loosened bolts from innerfender to cab which seemed to help some.
Old Mar 9, 2018 | 07:22 PM
FortyNiner's Avatar
FortyNiner
I can't tell from the pics, but the best practice is to assemble the front clip off the truck and then install. Short of that, loosely assemble the parts before tightening anything - including the inner fenders and the connections to the radiator brace.
Old Mar 10, 2018 | 01:17 AM
mod22's Avatar
mod22
Thanks FortyNiner that was one thing I was going to ask. Seems I could get the rear of fenders spread farther that way the front gap closed up and tight and then slowly bring the rear of fenders inward hoping that once those bolts are tight it wont allow it to seperate at the front panel.
Old Mar 10, 2018 | 01:16 PM
FortyNiner's Avatar
FortyNiner
From a practical perspective, trying to assemble the grille is a fastener intensive exercise. With all the goofy access angles needed, I found that it was best to get all those pieces fully together off the truck. Then the grille and valances are treated as big pieces of the puzzle - instead of an impossible collection of maddening parts.
Old Mar 11, 2018 | 03:46 PM
mtflat's Avatar
mtflat
Like FortyNiner, I assemble them as a unit upside down in order to reach the nuts and bolts. Fenders, grill, splash pan, upper and lower valance and then bolt on the truck.
COMPLIT1107
Apr 11, 2015 11:33 PM
montego69
May 17, 2013 04:41 PM
Stephen67
Jun 4, 2012 11:55 AM
midcal48
Dec 2, 2007 11:17 PM
52caddy
Oct 4, 2007 05:22 AM
