Transit Connect 2010+ Ford Transit Connect
Exhaust - is this normal?
Old 10-31-2018, 04:34 PM
JTB321's Avatar
JTB321
JTB321 is offline
In the process of changing out the wheels and tires for the winter I noticed both mufflers show signs of what I thought was leaking -
According to my Ford dealer this is normal for Fords? Apparently Ford have ‘weep’ holes in the mufflers to allow condensation to escape to prevent rotting from the inside out. Any thoughts/comments on this?
Looks like a fault to me and should be replaced under warranty.
John
Old 11-01-2018, 08:39 AM
camping nut's Avatar
camping nut
camping nut is online now
It is normal and there are weep wholes in it.
Old 11-01-2018, 06:47 PM
JTB321's Avatar
JTB321
JTB321 is offline
Thanks for the feedback. Still doesn’t seem right to me but I guess I’ll monitor it over the winter and see how it develops.
Old 11-04-2018, 09:44 PM
Fifty150's Avatar
Fifty150
Fifty150 is offline
That condition is actually worse, without the weep holes. Aftermarket mufflers rust out from the inside. Nothing that you can do about condensation. Even worse when the vehicle is not driven regularly. As temperature changes from day to night, or from cold to warm during the day, condensation is natural. You see it in the morning, where everything is covered in dew. Under your car, where there is no sunlight, the condensation collects and the moisture does not evaporate. In cold environments, it could be worse. In hot, dry climates, there is less humidity.
Old 11-05-2018, 05:53 PM
JTB321's Avatar
JTB321
JTB321 is offline
Thanks again, I’ll check it out after the upcoming Michigan winter!!
Dirtbag
21
02-10-2019 06:04 PM
Gear619
01-05-2016 07:10 PM
SuperDuty93
11-19-2012 10:00 PM
messeswithtrux
12-01-2007 08:24 PM
JohnT
Illinois Chapter
01-01-2005 03:21 PM
Quick Reply: Exhaust - is this normal?
