Diff fluid/gaskets???
Old Mar 8, 2018 | 01:21 PM
Justus6.0L's Avatar
Justus6.0L
I am going to be replacing my outer axle seals this weekend and though it would be a good time to open up my diffs and see how they look/replace fluid. What fluid is best? Is Amsoil good? Do the diffs use gaskets, or just rtv? Thanks for the input.
Old Mar 8, 2018 | 02:02 PM
Justus6.0L's Avatar
Justus6.0L
Never mind, I just found these:
Welcome to guzzle's Front Differential Maintenance Web Page
Welcome to guzzle's Rear Differential Maintenance Web Page
Old Mar 8, 2018 | 09:17 PM
WolfCreek540's Avatar
WolfCreek540
Rear axle seals? Be sure to check the dust/backing plate. These are prone to rusting out pretty quickly if you live where they are throwing salt on the roads. New ones (Usually Dorman is the only brand available for a decent price) will begin to rust in a year. The emergency brake pad assy. will rust out too, lock up, and cause the inner hub seal to fry. Usually this is found the hard way. Hardest part of the whole hub rebuild is getting the rotor to release because of corrosion. I use a bolt through the brake hardware mounting holes to apply enough pressure on the rear of the rotor and it POPS off. No, wait. the hardest part is messing with the emergency brake cable -- POS!
Old Mar 9, 2018 | 04:34 AM
Yahiko's Avatar
Yahiko
A Washington victim (Joined The Chapter Yet?) Anyway the RTV needs to be the
type that will resist the gear oil. That stuff will eat through the regular RTV is a short time.
The Ford TA-30 is the stuff that the dealer used and you can use stuff like Permatex®
Gear Oil RTV Gasket Maker
if you like and want to save some $.
Old Mar 9, 2018 | 07:47 AM
Justus6.0L's Avatar
Justus6.0L
When talking about axle seals I was referring to the front outer seals. I found these were bad when I did my brakes last weekend. I have the new seals and will be putting them on this weekend. Thanks for the information.
Justus6.0L's Avatar
Justus6.0L
I have joined the group here on the site for this area, is that what you mean?
Old Mar 9, 2018 | 01:59 PM
Yahiko's Avatar
Yahiko
Each state has a local chapter of FTE. Come on by ans say HI and join if you would like to.
Here is a link to the Chapter forum >>> https://www.ford-trucks.com/forums/forum188/
Per4mance
Jun 2, 2024 02:03 PM
JNG6
Feb 9, 2016 10:54 PM
995.4SD
Sep 26, 2013 12:57 PM
timmyboy76
Aug 17, 2012 01:38 PM
horseracer
1997 - 2003 F150
Jun 4, 2004 12:20 PM
