ebrake adjustment
Old Aug 16, 2012 | 08:14 PM
timmyboy76's Avatar
timmyboy76
ebrake adjustment
guys, not sure whats goin on. I replaced the p/s rear calipert hinking it was leaking. Well, still have a leak. Nowhere does it show on the caliper now and hard/soft lines. Whats weird is that, prior to having a blow out at the ramp (that was fun), there was no sign of fluid. I had to limp the truck up the ramp to the parking area (200yrds), changed tire and went on with the weekend. Didnt notice the fluid until last night, but brakes seemed good.
Anyway, replaced the caliper and still its wet from some where. I also adjusted the ebrake, but forthe life of me, can not get it to grab. Found the "star" at both sides, and still will role with pedal to floor.
Question is, does the ebrake have anything to do with this fluid loss and for the reason its not grabbing?
Old Aug 16, 2012 | 08:23 PM
Shanejet's Avatar
Shanejet
You might have blown the seal on the axle shaft. Does the fluid you are seeing smell like gear oil or brake fluid?
Old Aug 16, 2012 | 08:38 PM
Bonanza35's Avatar
Bonanza35
No the E-brake is all mechanical. You have to adjust both wheels. If you got the e-brakes wet they won't hold. I put new shoes on mine and they still didn't hold. Got a little better as time went on, but stil not great. If its brake fuild you are seeing, it mitt be a line being you blow a tire. Have somebody work the pedal and look real close. Start the motor also.
Chet
Old Aug 16, 2012 | 09:08 PM
timmyboy76's Avatar
timmyboy76
Shane...how can i inspect to see if it is a axle seal?
Chet...where's these "shoes' you talk'n about? Are they inside the hub assy or the actual brake pads that are on the caliper. If so, them are new.
Thanks guys for the responses, this gots me goin bonkers. Yet again, i throw $$$ atta part that probably didnt need replacing
Old Aug 16, 2012 | 10:03 PM
timmyboy76's Avatar
timmyboy76
ok, got rotor off, and the entire inside is soaked, smelling like gear oil. Anyone know how to go about get'n to the seal? Theres the end of the axle thats in the way, then all the ebrake shoe assy stuff.....really appreciate it guys.
Old Aug 16, 2012 | 10:05 PM
h2guy's Avatar
h2guy
Tim, don't want to be a smartA$$ here but with 2200 plus posts, you need to stop typing and read a little more.
A quick search turned up this thread that will tell you everything you ever wanted to know about servicing the ebrake/axle.
https://www.ford-trucks.com/forums/7...ake-shoes.html
Old Aug 16, 2012 | 10:27 PM
timmyboy76's Avatar
timmyboy76
no offense man, not sure if ur link isthe same, but found this from "camodown"....from the looks of it though, not sure if his link illustrated just the outer seal or if thatsthe only seal there....Mine looks to be leaking from within.
yup, same link.
Old Aug 17, 2012 | 12:47 PM
Bonanza35's Avatar
Bonanza35
You got to knock it out. Sometimes you will damage the bear also if you knock against it. When I did my E-brakes I replaced both seals, inter and outer, and bearing. Had one outside bearing by looking close that was just starting to go bad. There not that exspensive and it should last a long long time. My e-bakes looked new but still didn't hold well. So I put new on and they too didn't hold real well. Its just a bad design. Rememeber to check your Diff fuild when done and top off or change. Its Syn 75/140.
Chet
Old Aug 17, 2012 | 01:38 PM
timmyboy76's Avatar
timmyboy76
Thanks Chet...just ordered those seals that CAMO listed. When i getthere, i'll have them explode the screen and see about the inner seals. Got me the new pads as well and the special socket on order, should be in tomorrow...
P-51 Mustang
May 11, 2019 12:32 AM
joegeds
Mar 10, 2016 04:52 AM
Pookie's Dad
Apr 11, 2007 05:09 AM
92custom302
1978 - 1996 Big Bronco
15
Apr 14, 2006 04:35 PM
nothingbutford
20
Apr 30, 2004 01:14 AM
