Hydro locked????
Old Mar 8, 2018 | 10:40 AM
navistarnut's Avatar
navistarnut
Originally Posted by cookingguy
Ok. What's the best way to crank the motor by hand?
Pretty sure it needs to be in neutral
Edit..nevermind Mark beat me to the punch
Old Mar 8, 2018 | 10:54 AM
bismic's Avatar
bismic
Found what I was looking for in my spreadsheet:
Old Mar 8, 2018 | 10:55 AM
TooManyToys.'s Avatar
TooManyToys.
Maybe with a manual trans ........
Old Mar 8, 2018 | 11:04 AM
cookingguy's Avatar
cookingguy
It really looks like I can't get in to it without removing the fan shroud
Old Mar 8, 2018 | 11:24 AM
texastech_diesel's Avatar
texastech_diesel
Token Redneck
So pull the fan shroud. It takes maybe 10 minutes, that's better than trying to turn a locked motor with the starter.
Old Mar 8, 2018 | 01:29 PM
cookingguy's Avatar
cookingguy
Ok so hot the new starter in and got the truck to fire lots of white smoke not coolant smell more like fuel. So I shut it down pulled the glow plugs harness and pulled the glow plugs and cranked it with the starter using the jumpwr got a big poof out of the lat glow plug on the passenger side. Had a little poof out of the front one but it went away as it cranked it for a second. So I am thinking I am going after we that last injector on the passenger side
Old Mar 8, 2018 | 04:10 PM
SmackDaddy's Avatar
SmackDaddy
Sounds like that injector has a bad o ring or o rings and possibly copper washer was compromised. Just a guess. Pull the valve cover off, pop the oil rail off, pull the injector and see if it has any issues. Keep it clean in there if you do it and don’t drop anything in the motor. If you aren’t comfortable doing that your best bet is taking it to a shop.
Old Mar 8, 2018 | 04:14 PM
SmackDaddy's Avatar
SmackDaddy
Old Mar 8, 2018 | 04:32 PM
cookingguy's Avatar
cookingguy
Thats what I did I am putting it back together right now. I am very comfortable working on my truck . I have done lots on it in the last three years I have owned it
Old Mar 8, 2018 | 04:41 PM
SmackDaddy's Avatar
SmackDaddy
You have to love that passenger valve cover. I just rebuilt injectors about to fire her up.
bismic's Avatar
bismic
Just an fyi - cranking a hydrolocked engine puts excess pressure on head gaskets since liquid is incompressible. That is why we suggested only cranking w/ the glow plugs out. Maybe bend a push rod also (although I have seen this debated).
Old Mar 8, 2018 | 05:27 PM
cookingguy's Avatar
cookingguy
Fired it up and it is still smoking a bunch not sure if it smells like oil or coolant might just have to take it to the dealership for a diagnosis
Old Mar 8, 2018 | 06:18 PM
  #28
cookingguy's Avatar
cookingguy
Once I installed the starter I fired it for a second to make sure it was good then I pulled the glow plugs. And fired it with the starter. I saw that method on one of diseal tech Ron. I am pulling the glow plugs on the driver's side now going to try it on that side and see if I get fluid out of any of the cylinders.
Old Mar 8, 2018 | 06:47 PM
  #29
cookingguy's Avatar
cookingguy
Ok so the guys that did the work on this truck for the dealer I got it from we're stupid. They put rtv on the glow plug harness when they installed them and they didn't even repalce the harness which was broken at the little clips. So my front glow plug driver side is jacked the clip is broken. I took the fender well out and got in there with a long flat head was able to move it a little bit tried wiggling it and pulling on the wire and now the wire broke good time. Any hints on this one
Old Mar 8, 2018 | 07:06 PM
  #30
cookingguy's Avatar
cookingguy
