No low beams
Old Mar 7, 2018 | 06:48 PM
carsofchaos's Avatar
carsofchaos
No low beams
Hi All,
Have a great 72 F250 HighBoy I picked up awhile back and just now starting to sort through it. One issue that is has is that the low beams do not work at all. Neither do the tail lamps. Blinkers work, high beams work, brake lights work. I checked all the fuses and don't see any issues. Anyone run into this before and have a solution?
Thanks in advance!
Old Mar 7, 2018 | 07:40 PM
mikeo0o0o0's Avatar
mikeo0o0o0
First, not to insult your intelligence but make sure both low beams aren't blown. I've seen it before, one blows, the people don't realize it and keep driving until the other one blows and "oh cra**! I don't have low beams!.
If they're okay next suspect either the dimmer switch or low beam circuit. Because you have high beams, the wiring to the switch is okay. Check the low beam wiring starting at the plug on the dimmer switch. I've seen the wire break right at the plug. There is no fuse for the low beams. There's an internal circuit breaker built into the headlight switch.
Old Mar 7, 2018 | 09:00 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
X2 mikeo0o0o0 is spot on with his info.
And as always the more good - grounds the better.
Old Mar 7, 2018 | 09:42 PM
carsofchaos
I was wondering about the low beams, too. I know this truck sat for quite some time before I got it. I figured it wasn't them because the tail lights also don't work....of course they could ALL be burned out I suppose. I do remember a hi/low beam switch going bad on a 65 Mustang I had many years ago, so that's definitely a possibility. Once we dig out from the 24" of snow we just had dumped on us I'll get out to my shop and check the actual headlights before digging much further.
bill11012
Feb 18, 2023 05:30 PM
ITSOT
Oct 22, 2017 05:17 PM
Willfish4
2004 - 2008 F150
Jan 19, 2016 09:14 PM
Graeme
Feb 20, 2009 10:17 PM
wozxxx86
1978 - 1996 Big Bronco
Feb 6, 2005 08:43 PM
