Speedometer cable replacement help
Old Mar 7, 2018 | 08:59 AM
alfie623's Avatar
alfie623
I have a question about the tip of the speedometer cable and NOT the end that goes into the transfer case with the replaceable gear that changes the gage calibration.
I have a 1983 Bronco that came originally with a C6, 4x4 and cruise control. I've swapped in a ZF5 and kept the original NP208 transfer case. My original cable is frayed and needed to be replaced and was a few inches too short (the ZF5 is longer than the C6). I selected a cable from Rockauto that was appropriate for an auto trans with cruise but was slightly longer than my original cable. The cable was also listed as a suitable cable for a manual transmission. As you can see by the pictures the new cable doesn't have the plastic tip on it and I'm wondering if that will prevent it from working properly. Can anyone share what they may know about the tip and if I need it?
new cable with no plastic tip
old cable with plastic tip
Old Mar 7, 2018 | 09:29 AM
FuzzFace2's Avatar
FuzzFace2
Do you have the pictures mixed up?
I ask because I can't see how the cable with the round plastic part would work?
New cable with the plastic would protect it in shipping.
Dave - - - -
Old Mar 7, 2018 | 10:14 AM
alfie623's Avatar
alfie623
No, the pictures are correct. The newer cable (clean attaching nut) doesn't have the plastic piece.
Old Mar 7, 2018 | 11:48 AM
alfie623's Avatar
alfie623
Disregard my questions. After looking closer at the new cable I see it’s formed into a square shape and had the necessary stop crimped onto it.
gostephen
Mar 1, 2018 07:39 PM
Dean06919
Dec 4, 2016 07:23 PM
trokita101
Nov 3, 2014 08:29 PM
51PanelMan
Sep 13, 2012 02:10 PM
sparky
Aug 12, 2001 04:52 PM
