Cab removal
Old Mar 6, 2018 | 07:35 PM
Stu MacDonald's Avatar
Stu MacDonald
Cab removal
Im new here and this has likely been asked a million times but i am looking at getting a new f150 and heard you need to remove the cab to do simple things like the spark plugs. Is this actually true?
Old Mar 6, 2018 | 07:40 PM
JKBrad's Avatar
JKBrad
Untrue. Super Duties up until 2016 required that the cab be removed to work on the Powerstroke since it was packed in so tight. Don't know if that's still true for New Super Duties. The F150 never required the cab to be removed.
Old Mar 7, 2018 | 08:05 AM
GABAR's Avatar
GABAR
No, it`s not true and i`ve never seen that question asked about the current F150.
Go to a dealer and look under the hood and you`ll have your answer.
Old Mar 7, 2018 | 09:00 AM
storage_man's Avatar
storage_man
I would imagine that it depends on what you need to do. Just about for any basic maintenance can be performed without having to take drastic extraction measures ie Cab removal on either F150's or Superduties. But personally, I myself would not want to attempt to perform a complete engine rebuild on a 3.5 Ecoboost without removing the cab. It would be way more difficult and time consuming to attempt that.
Old Mar 7, 2018 | 09:58 AM
Kingofwylietx's Avatar
Kingofwylietx
......................you need to remove the cab to do simple things like the spark plugs. Is this actually true?
No. I read a thread on another site yesterday and a couple of guys posted that it took them approx 1 hour to change all their spark plugs.
Old Mar 7, 2018 | 12:37 PM
PupnDuck's Avatar
PupnDuck
Just out of curiosity, I checked the shop manual for the 2017 F150. There are 59 numbered steps to remove the 3.5EB engine that start with either the word "remove" or "disconnect". However the largest item that has to be removed is the hood. The entire engine / trans can be removed without touching the cab mounting bolts.
Old Mar 7, 2018 | 02:11 PM
85e150's Avatar
85e150
Once you pull all the tubing off the 2.7 you can almost stand in the engine compartment next to it.*
*must be skinny
Old Mar 7, 2018 | 07:21 PM
CA55F100's Avatar
CA55F100
They didn't left the bed to change the fuel pump in my full 36 gallon tank. I doubt they would lift the cab.
sgrol
6.7L Power Stroke Diesel
Jul 31, 2017 09:27 AM
bkuuz1
May 2, 2010 06:24 PM
tgene
6.4L Power Stroke Diesel
Aug 30, 2007 05:15 AM
wantaford
Aug 24, 2007 09:22 PM
