I have replaced the CPS sensor and figured it would fix the hiccup issue.. But nope, still does it and it is really starting to **** me off. But my air filter is in need to be changed, could that be a possibility? or maybe a ICP? Its a 94.5 psd. HELP!!!
FYI: He accidentally posted up on the 6.7 section first and I ran across him. Here's what's been said so far.
Originally Posted by F350-6
Any dash lights flash when this happens, or does the CEL light up? Are you using a Motorcraft branded CPS or a generic one? There's years of stories about the generic ones not working right. ICP or IPR wiring that's chaffed could be another possibility.
For better results, scroll to the top of this page and you'll notice you're in the 6.7 diesel section. Click on the word diesel, before it has the >6.7 Power Stroke Diesel and it will give you a list of the different generation diesel trucks to choose from. If you scroll down the list, you'll find the OBS section for the 7.3 and you'll get more answers if you post the same question there.
Originally Posted by OBSpsd12
Yeah i noticed that was in the 6.7 when i posted. but yes all those lights come on when it happens then it goes away, even the wait to start comes on
Lights flashing sound like a short to ground issue that makes the computer hiccup. ICP or IPR pigtail, wiring between the IDM and valve covers, or possibly the IDM itself if it's gotten wet lately. CPS issues typically just set the CEL after 3 or 4 hiccups, and it leaves a code. The short to ground just leaves a KAM code that points you towards batteries.
I'll check down in the OBS section to see if you posted there.
