6.2L V8 Discuss the 6.2L V8
Almost maxed out the GVWR today, truck didn’t mind at all
Old 03-06-2018, 03:34 AM
Addison86's Avatar
Addison86
Addison86 is offline
So I had to pick up a pallet of salt to take to a customer 4 hours away. With everything else in the truck, it’s right at ~13,500 lbs, probably closer to 13,800 lbs with my helper tagging along. GVWR for the truck is 14,000 lbs.
Truck barely squatted and handled the load fine. The truck is obviously a little slower to accelerate, but it’s really not bad at all. It doesn’t feel much different than usual (usual weight is just under 11,000 lbs).
Old 03-06-2018, 04:54 AM
tibadoe's Avatar
tibadoe
tibadoe is offline
Just another walk in the park for the F350.
Old 03-06-2018, 05:42 AM
Chuck's First Ford's Avatar
Chuck's First Ford
Chuck's First Ford is offline
there is a FEW 'k' planned in.. go you were Good..
on the other hand.. yesterday... a tired F 150... with a pallet of roofing shingles.. stacked higher then the cab.... riding Hard on the bump stops... bouncing down the road :WOW....
Old 03-07-2018, 10:24 PM
Tarster's Avatar
Tarster
Tarster is offline
I had my truck at 14,400 before it felt soft but it held the load real well.. my f350 is gvrw at 10k but it's the 3 leaf with helper spring so probably identical to yours.. good to know it can do the load without an issue.
Old 03-08-2018, 09:18 AM
rvpuller's Avatar
rvpuller
rvpuller is offline
My last 2 CCLB F350 SRW were loaded to max GVWR 24/7 when I had the 8.5 utility box cleaned out then I would load it down with that days job, it took it without any complaints but because it was a SRW it was hard on rear tires.
Denny
Old 03-11-2018, 09:09 PM
J Standard's Avatar
J Standard
J Standard is offline
I see the Florida DOT guys running trucks just like that with trailers in tow with skid steer on them. All 6.2's...
I have yet to not be impressed the the 6.2 and I am a die-hard GM guy.
Old 03-11-2018, 10:31 PM
Flatbed Ed's Avatar
Flatbed Ed
Flatbed Ed is offline
A F350 can handle a heavy payload. Mine has Timbrens for assist. 5 to 7k, no problem. I once hauled about 9k lbs. from Houston to Louisiana. Was happy to get it off, but the truck did it.
The shipper SAID it only weighed 6k.....they lied !
Old 03-14-2018, 07:36 PM
Bugzilla46310's Avatar
Bugzilla46310
Bugzilla46310 is offline
Is your big helper a big help?!?
Old 03-14-2018, 08:03 PM
Tarster's Avatar
Tarster
Tarster is offline
Not sure if your referring to my post, I think it is just the factory one, I have never measured it to see.
Old 03-14-2018, 08:32 PM
Ron94150's Avatar
Ron94150
Ron94150 is offline
Good to hear from you Ed. How many miles on the truck now?
Old 03-14-2018, 08:45 PM
Flatbed Ed's Avatar
Flatbed Ed
Hi there. I now have 495,000 miles. No new issues to report....
Old 03-21-2018, 08:38 PM
Clinton Sprabary's Avatar
Clinton Sprabary
Clinton Sprabary is offline
what’s your empty weight ed?
Baatzy
05-08-2018 09:44 PM
vavtx
2017+ Super Duty
05-29-2017 08:02 PM
Larietpsd
2015 - 2020 F150
05-02-2016 05:27 AM
BigF350
6.7L Power Stroke Diesel
29
03-29-2014 09:20 AM
Alex332
07-21-2008 06:52 PM
Quick Reply: Almost maxed out the GVWR today, truck didn’t mind at all
