16x6 tires
Old Mar 5, 2018 | 06:50 PM
KirkF's Avatar
KirkF
16x6 tires
I'm getting ready to order up new rubber for my project. What I'm looking for is original look 'pie crust' rubber in 16x6, blackwalls.
Can someone tell me which brand they used and are happy with?
And do you run tubes or tubeless?
I was thinking of staying with bias plies.
Thanx,
Kirk
Old Mar 5, 2018 | 07:07 PM
abe's Avatar
abe
Thanx,
Kirk
I have Excelsior's on my 54 F100. They are bias ply. They have the pie crust look. I am pleased with them. The tire shop says new bias plies are better than they were years ago. I had radials on my 54 from 1999 to about 4 years ago. They rode nice, made bumps smoother but we're very very hard to turn the wheel when parking, backing, or going very slow. I'll post pictures when I get to my desktop.
Old Mar 5, 2018 | 07:22 PM
KirkF's Avatar
KirkF
I should also mention this is for stock 16", 1950 f1 rims.
I have no idea how the widths work for bias plies. Do you use 600x16 or 700x16 or 750x16?
The one tire on there now just says 16x6
Kirk
Old Mar 5, 2018 | 07:23 PM
abe's Avatar
abe
Here is a close up of my 16x6 Excelsiors:
Here is my truck with the bias plies on front and the old radials on the rear.
Old Mar 5, 2018 | 08:39 PM
FortyNiner's Avatar
FortyNiner
I'm running Firestone 650x16s on the F1 and will have 600x16 Ford scripts on the 46 project car - both bias ply tubed tires. Good pie crust on both and zero handling issues with the F1 for the past 5 years.
My only caution would be to try to find an experienced house to do the mounting. After a few ruined tubes, I resorted to doing the mounting myself - I'll have my guy just do the balancing.
Old Mar 6, 2018 | 07:52 AM
EffieTrucker's Avatar
EffieTrucker
Phantom of the Phorum
OT
Abe, one of the things I love about your truck, and others on this forum, is that in black and white
(minus the soccer *****) this picture could have been taken in any decade. From 1950s to 2010s.
Old Mar 6, 2018 | 11:42 AM
52 USCG Panel's Avatar
52 USCG Panel
I'll second what Forty-Niner said about finding an experienced shop to mount your tires. I'm running 6:50 X16 bias tires with tubes. Two of the tubes developed leaks because there was a problem with how they were installed. The shop that did the work does lots of work for farmers and said they were familiar with rims needing tubes, but I had trouble anyway.
Jim
Old Mar 6, 2018 | 01:50 PM
abe's Avatar
abe
Thanks, Ken. That's my plan. To keep the truck, to the best of my ability and wallet, the way it was when grandpa had it.
Old Mar 6, 2018 | 03:24 PM
KirkF's Avatar
KirkF
Looking at Coker Tire, they list the Firestone Bias Ply Zig Zag Tread Blackwall with an available size in 650x16
https://www.cokertire.com/tires/bran...blackwall.html
I see Excelsior tires on there as well, but I'm not sure which model they would be.
Do you buy 5 tires the same size, or does anyone try and go a bit wider on the rear tires?
How wide a tire can you fit on the stock 16" rims? What is the actual 16" rim width?
They certainly aren't cheap. Looks like it will be around $900 USD to get five Firestones.
Kirk
Old Mar 6, 2018 | 04:36 PM
abe's Avatar
abe
I got my Excelsior's from a local tire store. I think the total cost of them with mounting was around $100 per tire.
Old Mar 6, 2018 | 06:24 PM
52 USCG Panel
The tires I purchased from a Coker dealer were manufactured by the Tornel Tire Company. They were not as expensive as some of the options I considered, but still not cheap. The reviews I looked at were mostly positive. Good luck with your decision.
Jim
Old Mar 20, 2018 | 11:46 AM
KirkF's Avatar
KirkF
F-Series Tire Sizes
For radials, it looks like the closest size is 215/85-16s
Can anyone with a 48-52 F1 tell me if there is any issues with fitting the spare tire with this size?
For reference I've attached a wheel chart, for future reference.
Thanx,
Kirk
Old Mar 20, 2018 | 12:44 PM
KirkF's Avatar
KirkF
Another couple questions:
1. For a 6.50 x 16 bias ply, which tube do you buy to go with it? There is a million tubes on the coker site.
2. For those who used a radial tire, did you use a tube or go tubeless? And if you did use a tube, which one?
Thanx,
Kirk
Old Mar 20, 2018 | 01:55 PM
FortyNiner's Avatar
FortyNiner
Based on past threads, most any tire other than a 650x16 is going to be a problem with your under bed carrier. The width of the tire is the issue. This makes sense to me as the 650s are a snug fit.
On the tubes, I'm running these:
https://www.cokertire.com/gr16-165-1...dial-tube.html
Old Mar 20, 2018 | 01:57 PM
chriscris's Avatar
chriscris
Coker has a 'bias ply look' radial available as well (if it hasn't been mentioned)
