Sponsored by: Real Truck
OBDII Reader for OBDI?
Old Mar 4, 2018 | 05:09 PM
ligito's Avatar
ligito
Will an OBDII reader work on a 99, with an OBDI port?
Old Mar 4, 2018 | 09:28 PM
Djosbun's Avatar
Djosbun
It will not. Plug is physically different. You can still by the old ODB1 readers, though.
— Dave
Old Mar 4, 2018 | 09:44 PM
geekwithoutacause's Avatar
geekwithoutacause
Is it the same plug ? A lot of these heavy trucks are not obd2 compliant but still work.
Old Mar 5, 2018 | 05:46 AM
Chuck's First Ford's Avatar
Chuck's First Ford
deleted... OP can not read links
Old Mar 5, 2018 | 05:54 AM
projectSHO89's Avatar
projectSHO89
The premise for the original question is mistaken, there is no OBDI plug on a 99 SD. A 99 Super Duty will have an OBDII electrical interface, not OBD1. However, unless the truck was a "green state" version from the factory, it will be running an OBDI calibration on the OBDII hardware platform
So the, correct answer is "Yes, the OBDII reader will work just fine since the 99 does NOT have an OBDI plug."
Old Mar 5, 2018 | 09:05 AM
geekwithoutacause
That's what I thought. It's probably the same as it is on my 2001. IT has the same connector as OBD2 yet is not calibrated the same as for trucks sold in California. Used to have one of those too.
Hence why I asked if the connector is the same. Other people spewing mis-information on here.
Old Mar 5, 2018 | 09:30 AM
Chuck's First Ford
search is your friend
OBDII - On-Board Diagnostic's System - Does My Car Have OBD-II? The Connector and Communications.
OP can or will not read a link.. PROOF what he has..
Old Mar 5, 2018 | 07:46 PM
ligito's Avatar
ligito
Let's try this. Will an OBDII reader work on a 99 F250 SD V10?
Will it read any codes, or do I need to do something else?
Old Mar 5, 2018 | 08:00 PM
dirthawg's Avatar
dirthawg
Yes.
All Cars and light trucks built and sold in the United States after January 1, 1996 were required to be ODBII equipped.
OBDI connector looks like this and is usually located under the hood near the brake master cylinder.
Old Mar 5, 2018 | 08:22 PM
geekwithoutacause
YES ! Ignore all the other nonsense. You have the obd2 connector. It will work.
Old Mar 6, 2018 | 03:57 AM
Chuck's First Ford
WOW !!!!!!!!!
Old Mar 6, 2018 | 11:22 AM
geekwithoutacause
An easy way to verify is to take it to autozone or o'reillys and ask them to scan it. It's free.
Old Mar 6, 2018 | 11:36 AM
Misky6.0's Avatar
Misky6.0
My '99 F350 V10 has OBDII and my Scangauge2 plugs right in and reads the available sensors just fine..
Old Mar 6, 2018 | 08:49 PM
ligito's Avatar
ligito
Thanks for the responses, both sarcastic and useful.
Old Mar 7, 2018 | 08:08 AM
Chuck's First Ford
if you did not read the link I provided..
the USA federal LAW.. vehicles must have OBDII.. 1/1/1996..... so 1999 must.
