the USA federal LAW.. vehicles must have OBDII.. 1/1/1996..... so 1999 must.
You forgot the exceptions.... and the vehicle under discussion in this thread falls into that category.
See post #5.
The following excerpt is from the 1999 Ford OBDII documentation that can be downloaded for free from Ford.
[QUOTE[i]]If a vehicle is not required to comply with OBD-II requirements, it utilizes an OBD-I system. OBD-I systems are
used on all over 8,500 lbs. GVWR Federal truck calibrations. With the exception of the 1996 MY carryover EEC-IV
OBD-I systems, Federal > 8,500 lbs. OBD-I vehicles use that same PCM, J1850 serial data communication link,
J1962 Data Link Connector, and PCM software as the corresponding OBD-II vehicle. The only difference is the
possible removal of the rear oxygen sensor(s), fuel tank pressure sensor, canister vent solenoid, and a different
PCM calibration.[/QUOTE] I added emphasis for key portions.
