Sponsored by: Real Truck
backup lights
Old Feb 28, 2018 | 07:29 PM
Irtnog's Avatar
Irtnog
backup lights
I bought a set of aux LED back up lights for my 2000 F350. I am not anywhere close to being a mechanic or electrical engineer. I want to wire them so that they come on when I put the truck in reverse. Can I just splice them into the wires that go to the stock reverse lights?
Old Feb 28, 2018 | 07:32 PM
ligito's Avatar
ligito
Yes, but you may need a resistor.
Old Feb 28, 2018 | 07:46 PM
Colorado350's Avatar
Colorado350
You can splice in the stock wiring. Since you're only doing back up lights, You can splice into your 7 pin too. You won't need a resistor, I wired in a LED light strip to a trailer side 4 pin and plug into my 4 pin harness, works fine.
Edit: reworded for clarification...
Old Feb 28, 2018 | 09:03 PM
projectSHO89's Avatar
projectSHO89
You will NOT need a resistor if the lights are designed for 12 volt systems.
Since they're LED, they probably draw very little current and you can just run them in parallel work or in place of your regular backup lamps.
I wired in a light strip to a trailer side 4 pin and plug into my 4 pin harness, works fine.
Won't work for backup lights since the 4-pin trailer connector doesn't have the reverse lamp signal on it. You'd have to get it from the 7-pin, if properly equipped.
Old Feb 28, 2018 | 10:05 PM
Colorado350
Your misunderstanding my point, my LED light strip doesn't cause interference i.e. No resistor needed. s
Old Mar 1, 2018 | 06:30 AM
projectSHO89
The comment regarding the resistor was not related to your previous comment. The part about the back lights and the 4-pin was. Don't know what kind of "light strip" you installed, but it couldn't be applicable to what the OP was asking about.
Old Mar 1, 2018 | 06:08 PM
ligito's Avatar
ligito
Now, kids, don't fight.
Old Mar 1, 2018 | 06:50 PM
I-Toon's Avatar
I-Toon
I upgraded my reverse lights from the regular bulbs to Astar 1200 LED bulbs with projectors. Just over $20 on Amazon and the difference is night and day.
Old Mar 1, 2018 | 06:52 PM
projectSHO89
Who's fighting? I'm just clearing the air by pointing out that well-intended but inapplicable information is, well... inapplicable ... to the subject under discussion. Keeps the OP from wasting time chasing down rabbit holes out in the weeds.
Old Mar 15, 2018 | 05:59 PM
Irtnog's Avatar
Irtnog
I wired a pair of AuxBeam 4" LED backuplights like this: Hot wire from battery to a 40A relay, wire from the drivers side stock light to the relay so that the new lights will come on when I put it in reverse, red to a pole on the relay and black to a ground pole on the relay and grounded to the frame, but they still don't work. One other note, the passenger side stock reverse light is not working. I replaced a bulb but it won't light up. What have I done wrong? Is it possible that the passenger side light not working would impact the aux lights that I just installed? I'm going to check the power on that light and see if perhaps I need a new connector. The truck is 18 years old now so I suppose that's possible. Any ideas friends?
Old Mar 17, 2018 | 06:45 PM
Irtnog's Avatar
Irtnog
so i finally wired each side into the corresponding hot on the stock lights and put the grounds together to a common ground. I got rid of the relay. They work fine now.
oxt127
All Things Towing
Feb 8, 2016 05:10 PM
IdrinkPBR
Electrical Systems/Wiring
Aug 19, 2014 07:22 PM
dannyo
Oct 27, 2008 09:50 PM
Ponyexpress
Jan 2, 2007 09:52 AM
breece
Apr 30, 2004 11:04 PM
