Starting Problems
Old Mar 4, 2018 | 01:46 PM
okrp's Avatar
okrp
Starting Problems
I have a 2000 7.3 that the belt broke. Put a new one on and it will not start. This is not the first belt I have replaced. Just the first time it has not started right up.
Old Mar 4, 2018 | 01:52 PM
AllaboutMPG's Avatar
AllaboutMPG
How old was the belt? Could your ac compressor or other component be dragging causing slow rpm during crank. If rpm is not high enough it will not crank.
Old Mar 4, 2018 | 02:00 PM
Chevota_72's Avatar
Chevota_72
When the belt broke did it rip any wiring out with it? Maybe caused wiring damage and blew a fuse?
Old Mar 4, 2018 | 04:57 PM
okrp's Avatar
okrp
I looked at the wiring and didn't see any damage.Didn't think about a fuse but it is with a look.
Old Mar 4, 2018 | 04:58 PM
okrp's Avatar
okrp
It cranks fine just acts like it is not getting any fuel.
Old Mar 4, 2018 | 05:01 PM
Walleye Hunter's Avatar
Walleye Hunter
There's a couple of sensors in there that might have gotten taken out. The CPS comes to mind, it's front of engine, passenger's side down on the front of the block, if that got taken out you'll not run.
Old Mar 4, 2018 | 05:23 PM
Chevota_72's Avatar
Chevota_72
Did the engine die when the belt broke?
do you get the "wait to start" indication when you key on?
Old Mar 4, 2018 | 07:58 PM
okrp's Avatar
okrp
[QUOTE=Chevota_72;17840813]Did the engine die when the belt broke?
Yes that is exactly what happened. Here the belt coming apart and the truck stalled.
Old Mar 4, 2018 | 08:00 PM
okrp's Avatar
okrp
[QUOTE=okrp;17841080]
Heard the belt break.
Old Mar 4, 2018 | 08:09 PM
Chevota_72's Avatar
Chevota_72
I'm positive it ripped out wiring somewhere. As walleye suggested check the CPS.
texasjack
24
Apr 10, 2021 10:10 AM
alfred56
Dec 5, 2013 09:49 AM
jedennison
13
Jul 6, 2009 09:07 AM
captaingofast
1983 - 2012 Ranger & B-Series
Feb 6, 2007 02:04 PM
cadiecast
Aerostar
Aug 27, 2002 12:39 PM
